SET ST536v6 to bridge mode
Leewayz
Yes, you r right
Is it norm that after flash to bridge mode.
the following 2 mode on the modem no long available, even with direct connect to ethernet?
1. browser 192.168.1.254 - not accessible anymore?
2. telnet 192.168.1.254 - not accessible anymore?
Diavonex
Leewayz is correct.
You do not flash the ST536v6 to bridge mode, you set it to bridge mode.
If you want to revert back to Gateway, just hard reset your ST536v6.
pcteo
Leewayz is correct.
Yes using the residential cd to set.
OK. thks
Diavonex
OK. thks
The Residential CD will set your ST536v6 to bridge mode.
The word flash is incorrect.
Once in bridge mode, you'll not be able to "enter" your ST536v6.
pcteo
Yes, I just compare it with AM300, which actually option to set to bridge mode.
But, this st536v6, use cd to set.
both use different methods to set.
Diavonex
Singtel's firmware do not allow for bridge mode.
If you buy a retail version, I'm sure you don't need the Residential CD to set bridge mode.
lemonn
So to set it to bridge mode I need to use the Residential CD?
Diavonex
Method 1
1. Hard reset the ST536v6
2. Connect to router WAN port
3. Set PPPoE
4. Surf the net
Method 2
1. Use Residential CD and set ST536v6 to bridge mode
2. Connect ST536v6 to WAN port of router
3. Set PPPoE
4. Surf the net
Certain people encounter problem using Method 1
pcteo
Method 1
3. Set PPPoE
4. Surf the net
Method 2
3. Set PPPoE
4. Surf the net
I was told is from singtel, but didnt see singtel logo.
firmware is 6.2.17.5
Just want to use it as pure modem, so didnt try method 1.
lemonn
Thanks Diavonex!
BT seems faster now and no more Low IDs on emule :s13:
tungsten2
A more detailed method supplied by tidus792 in another thread
Method 1a (Modified)
1. On your router, Set PPPoE, Configure username and password.
2. Turn off Both modem and router.
3. Connect modem to router.
4. Turn on the modem and do a Hard reset the ST536v6 by pressing on the reset button till the power led turns red.
5. Turn on your router.
6. Surf the net
liangtam
Most of the steps in 1a is quite redundant actually.
EDIT:
Just remembered
Method 3: CLI (not tested personally)
Method 4: Half-bridge (tested on 7.4.1.7)
Ev0d3vil
Okay guys, i used method 1a, i can surf the net now, But, i cant access my modem? whats happening.
liangtam
This is normal. IF you wan to access the modem, u will have to either
1)Remove ur router and hook ur PC to modem direct
2) Hook a switch in between modem and router, hook PC to switch and access it without interrupting internet while accessing.
