DNS-323 Network Storage
Rogue
Alternatively , you can use rsync. Need some knowledge of linux. Goggle about it.
It can do an incremental file / directory synchronization based only on files that have been changed or only the parts of the files that have been changed. It helps to synchronize not only with local mirror folders, but also remote folders.
shadowandy
if it is just a one time affair then doing a cp would be fine as the very first time rsync runs, it takes a very long time, longer than a simple cp
alpc
Ok, I suppose that would be the way... except I am not home for a mth to do this... Sigh....
Errz
am having problem with mldonkey. When I restart the DNS-323, the mldonkey doesnt auto start.
when i telnet in (port 23) and type in /mnt/HD_a2/mlnet.sh, nohup: appending to nohup.out appear
have uploaded mldonkey.2.9.3.lite.realsimple.zip
n0d3
Chiu is noob lah Errz, MSN me arso so blur.
To have it autostart move the .sh script to the start folder.
# cp /mnt/HD_a2/mlnet.sh /mnt/HD_a2/fun_plug.d/start/
# chmod a+x /mnt/HD_a2/fun_plug.d/start/mlnet.sh
# reboot
Errz
# reboot
eh no leh
Instructions
1. Unpack the contents of archive to Volume_1 (/mnt/HD_a2/)
2. Reboot DNS-323
3. Wait a while for MLDonkey to start
4. Go to MLDonkey page at http://<dns-323 ip>:4080
username: admin
password: <blank>
website: http://www.shadowandy.net
funplug: http://www.inreto.de/dns323/fun-plug/
MLDonkey: http://mldonkey.sourceforge.net
MLDOnkey DNS-323: http://www.shadowandy.net/_html/archives/tech/dns323/
NOTE:
mlnet.sh set to auto start.
To disable, comment off the last line of fun_plug (/mnt/HD_a2/mlnet.sh)
come ! MSN!
pepsi76
Can anyone confirm upgrading from 1.03 to 1.04 does not wipe out the data in the hdd? Thanks!
Rogue
Nope it does not wipe your data.
It might become inaccessible if the machine bricks on firmware update(might happen if you have a sudden power outage while updating), but data is still safe, only the firmware is screwed for this case. Then just use another machine or wait for repairs to access your data.
Deavenger
Deavenger - download ms netframework 1.1 and 1.1sp directly from microsoft.com and install it before runnin g the memeo setup.
I did that but it seems vista clashes with netframework.. always shows me an error at the end of the installation and asks me to terminate the program
Errz
isit the limitation of mldonkey that bt is slower ?
download the same stuff from PC(utorrent) am getting high speed , but from dns-323, its terrible.
richneo
thats why shadowandy is trying to find other BT clients such as ctorrent, rtorrent and etc
pepsi76
Thanks bros!
duffy
harlo ppl, this one, can i put one bay 500gb, one bay 320gb?
any implication?
Rogue
any implication?
Other than RAID is limited by the smaller sized HD, it's still usable though not optimal.
There's also options for non-raid. Either you setup to treat each bay as separate HD or both bays are one big HD via JBOD.
duffy
wat u mean by smaller HDD?
djcoolmax
mean... if you have 2 HD each with different capacities, when you do RAID-0, your volume will as large as your smallest capacity HD.
so if you have a 320GB and a 500GB, when you do RAID-0, you only get 320GB on your 500GB drv. :yawn:
richneo
i would like to correct something here
if u have a 320gb and 500gb to run raid 0, u will get 320gb x 2 = 640gb
raid 1 is mirroring. oni when u run riad-1 aka mirroring den u get 320gb with both 320gb and 500gb hdd
