iRobot Scooba experience
frankman
wow, how did you get 15% discounts one?
Me too, want to know how??? Recently, check with a shop at SLS level 2 quoted labour (7 working day) and parts 3300mAh for my dead battery at $94.00. I think we should arrange with this shop that all our dead batteries send it to them to fix and ask them for a better price.
hq83
after u register your account with them, they will send u a email with the discount code.
i think mosmos post the code before. not sure is it the same 1.
the discount code only work for the 1st purchase.
WJY
just a question, how frequent you pple put roomba to work??? if i use it daily does it affect the battery life? or should i use it once every 2 day?
hq83
mine is working everyday at least once per day...
sometime 2 per day.. batt about 5months already. still working as normal.. more than 1hr30mins.
mosmos
High Honorary Member
almost everyday for mine now, but only run half of 5-room flat, exlucding balcony + kitchen.
bahang
How long can a roomba continue to work when the battery turn from green to amber light?
bahang
Im interested.
hq83
nv go and monitor and time how long it take for the light to change from amver to red..
only know that max mode last 1hr30mins b4 it go back to the docking station and play the mission completed sound.
frankman
When I register with them, they did not send me any discount code. Can you state your discount code for me to try thanks.
hq83
mosmos or anyone can help me?
will the scooba see the roomba docking station and dun go near it ?
or it will juz bump into the roomba on the docking station/go on top of the docking station
hq83
Really? IIRC, I did see my scooba crash into my roomba docked at docking station. I need to use a virtual wall to block it
mine didnt go near it for the past 30mins.... still running now..
edit: it did crash into the roomba at docking station.
hq83
dankoo
funny...mine did not..both using same virtual wall and I presume that it should be the same for the docking station.
