Showcase your home theater setup thread
gaolow
it a fix wall type with metal frame. i got post a picture under this thread, can refer to my 2nd reply at page 2 of this thread
iMbEst
MaTriX07 said:
any idea where to get this kind of portable screen? how do you place your projector?
TsQ
iMbEst said:
OMG!!!! how much did you pay for it?
for a 70-80" shld be SGD3k .. anyway the larger size dont really mean more expensive for stewart screens..
I got my firehawk 80" 2 yrs back for ard $3k+ .. cannot remember the exact amount already. Made to order if they dont hv the typical size.. so once deposit paid, they will sent from US and reach here ard 4-5 days.
here a older pic..
iMbEst
wow, looks impressive. but my problem is I can't use fixed screen for the limited "TV" area. Need to adopt a 42" or 50" Plasma at the same time, that's why need a mobile type of pull down type of screen lor....
Pull down type seems better but scared it make the place ugly leh...
wyeng09
hi guys would you all know how much to replace the projector lamp and where to go to? thks
TsQ
depands on model... $600-1000 and over also got.. most home use ones are below $1000 unless u using super high end stuff
wyeng09
thks.. whoa.. thats ex... my is hyundai one home used.. where to get huh? if so ex better get a brand new one huh...
s17oopy
well just to let u guys know if u wan to know more about lamp price or projector or screen then let me know.. for projector only some brand have hor let u guys know.
blueweed
quick question guys. I am building a home theater room and I have around 3.6m to where I will be sitting. I was recommended a 90inch(max) given I will be watching movie and playing FPS games. Apparently more than 90inch at this distance with FPS games will make one giddy. Anythoughts here? thanks
TsQ
yes... google for viewing distance.. THX got a recommendation.
Dont think ur wall can take big means u must max it.. else yes, will make u very very uncomfortable .. some ppl even wanna puke after watching a movie.
Assuming you have light coloured walls, why don't you put up all the other equipment first, project onto the wall where you intend to put the screen, and adjust the image till it suits you. Then measure the approximate viewing size and buy a screen to match?
LeiTeo
Question
In the process of setting up my "low cost" "high impact" Home Theatre System.
Just placed an order for a Dell 2400MP Projector
Next, a Creative Giaworks S750 7.1 speaker set and a DDTS-100 decoder.
Finally a simple pull down projector screen.
Total Cost:
$1549 for the projector + $100 for wiring
$799 + 299 for the speakers + DTS decoder
$399 for a 96x96 Lav manual projector screen.
S$3046.
The diagonal 4:3 image is 120", 16:9 image is 110"
Will be running the multimedia from a multi-format Ichiban DVD mini-hifi player (plays Mpeg4), a DIY media PC + a DIY 1TB Multimedia File Server (4 x 250GB in RAID 0).
Will post images once project is completed
Hey DL,
Can you introduce me to the one who helped you do the whole set up?
MiNdFrEak
Hi there, can anyone direct me to where i can purchase a InFocus SP4805 online sg websites or shops in sg. Thanks a lot!
petetherock
Moderator
Moderator
Bro this projector is really old, I sold mine 2 years ago.
You can try 2nd hand shops or sell sections but the cost of the bulb will be high.
For 1000 you can get new office style ones with igher specs or import from Amazon some of the newer In Focus models.
See projectorcentral.com
And this is the wrong place to ask as well
rasserie
just something to share,
im currently testing a projector for a fren.
but i do not have a screen,
my walls are all either light red or light blue in color, no whites
so what i did is to get a white blind from ikea at a cost of 59 bux.
then use scotch tape to temporarily install the blind on a cupboard.
the blind is like those pull down projector screen.
as far as i can tell, it serves as a very cheap imitation projector screen quite well.
rather than get a dedicated projector screen, id get a temporary blind for a temporary projector.
junkai21
Deluxe Member
Great. How big was it?
