a seal is sth that prevents oil leak right?but if i dont see any oil leaking leh,can i assume its well,hence continue to ride on until i see leaking?
else whats the duration to change and how much is the damage?
Pew is the one that recco me the XTC, "More bang for buck" thats what he said ... and the bling factor ...
The anthem is fast and nimble (according to reviews) ... and I think it would be more comfy for my back as i had a little back problem since young ...
Will need more comments ... Still have a long way to go until zero hour ...
yeah... i notice i can pull away faster on my HT then my fren FS s-work M5... on the road, i also find accelerating harder on the s-work even though its rear shock is locked out...http://www.taycycle.com.sg/2008/bike_giant_anthem_2.shtml
http://www.taycycle.com.sg/2008/bike_giant_xtc_a0_d.shtml
Comparing between these 2 with a similar price bracket, the HT comes with LX, XT components and FOX F100 Fork and the bling bling of carbon seatstay for greater stiffness.
HT will offer greater peddling efficiency without the bob of the rear shock. And of cuz, the HT is alot lighter.
For the FS, it offers greater traction offroad (can afford to bash through more things without flying off ur bike) RP2 even with pro pedal on, it will still bob especially when meshing, so onroad will be slower especially climbing.
Mine's an Anthem 1, but using Anthem 2 frame as Tay only had the 2 in Large sizebro,you riding anthem 1 meh?i thot was anthem 2?
Hmm, the Anthem on flat ground can't feel any bobbing, visually also don't see the shock compressing at all unless got bump![]()
Nope.. today rest day LOLtheo,today never go ecp arh?i went cycling today hoping to spot a anthem.but what i spotted was this trek FS.cool man...ang moh damn rich sia
None also, the only thing that'll bob is the front fork, but can be locked outHow bout cranking uphill?
pew can share what are the necessary servicing/maintenance needed for a FS?please tell me what are those that really die die must service part and those that can skip one...
Hehehe, my Anthem 1 currently weighs in at 27lbs, looking forward to upgrading wheelset to bring it down to 26lbs or lower(1kg = 2.2lbs)
Save 1 pound probably quite easy.
Change the tires (stock wire bead tires weigh a ton my guess 700gms per piece?) I just changed to a pair of Maxxis Ignitor 1.95 exception series stated weight 505 gms per piese, but actual weight 450-480gms)
Take away the reflectors on the wheels, (maybe 20-30gms)
Change rim tape to Velo plugs (save more than 50gms)
Change grips to Titec Pork Rinds (Can save almost 100gms)
Oooo haha ok will try, thanks!Any idea how good the Panaracer Fire XC Pros are?
