The Spectacles Thread.
jujube
want to get a cheap pair for home use. got any budget lobang ?
bencheongcm
anyone knows where can I get discounted tag heuer specs frame as I know their price is controlled
hydecat
hi guys,
just went to a shop to make a half-frame specs. I wanted the lens to be glass instead of plastic but the shopkeeper say half-frame spec cannot have glass lens. This that true?
jujube
hi guys,
cannot drill into glass mah esp so small
hydecat
Thanks for the replies!
I have pretty high degree therefore I think using glass lens would be a better choice since they are cheaper and also thinner.
But now half-frame is only available with plastic lens, I will need to consider a full-frame instead...
xianmeimei
where is the best place to make specs in the western area?
I would like to know too. :s12:
I got my first pair last year from a chain shop and i think i got "carrot-cake-ed"
I hear its better to get from neighbourhood shops (cheaper), unless you are getting the branded kinds. Is it true?
But i see the ah pek sit there ( from the 2 shops nearby) ..i will -_-'''''
Nakedtoes
Bullsh1t lar.. cannot dril glass.. then how come last time i can make framless glass spec..
Now i am actually looking for shop to do it also... plastic lens sucks..:s27:
Nakedtoes
where got sell nike frame at good price.. very gian on one frame..
foofam77
anyone know where to make sunglasses where the lenses come with degrees?
Most imptly, must not have visual distortion.
Pls exclude Transition type of lenses. thanks
zhane
glass thinner for high degree?
