iRobot Scooba experience
ktee
cc billing address i filled in sg address. :s22:
Guess so. I also did But it show Singapore, Oregon, USA! hahaha. :s13: Sadly, there was no more stock and i was on a waitlist. Then they cancelled my order because (hopefully) the item was sold out. :(
ktee
A Warning to all who tried to buy Irobot from eBay:
I tried to claim my warranty from Irobot, this is what they reply:
Dear XXXXXX,
Thank you for contacting iRobot Customer Support.
We do apologize for the inconvenience. Unfortunately, any product purchased via eBay does not carry a manufacturer's warranty. If the seller states the product is guaranteed that is incorrect. We consider eBay purchases third party, which is stated specifically in our written warranty.
Title: iRobot Warranty
URL: http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=247
Thank you,
Lauren
iRobot Customer Support Supervisor
There are many ebay listings for iRobot which states got warranty, dont be fool. :eek:
Oh, i was trying my luck but failed. :( But HSN and Woot shld be safe.
thewiseone
Sigh... why u tell them u purchased from Ebay??! Just fill in online merchant like Amazon or Woot (but make sure that these merchants did sell yr model b4).
Dear XXXXXX,
Thank you,
Lauren
ktee
If i knew earlier, I wont even put eBay. Anyway, if they required receipt or invoice, we also doomed.
Now, i refrain from buying Irobot from eBay. Why buy fr eBay when you can get a good if not better deal from HSN like mosmos. :D
thewiseone
So far no receipts or proof of purchase required. :D
dankoo
My 2x560 finally reach vpost after much tracking...cos it was lost for a while...my "extra" 560 also arrives yesterday via UPS to Vpost...I guess will be doing a WTS soon...:)
mosmos
High Honorary Member
:eek: so lucky.
XxDrAg0nxX
Eh... why you buy an extra for?
How much?
ktee
Post some pics of cleaning my 4210s:
Roomba 1 before cleaning: DIRTY
Roomba 1 after cleaning:
Roomba 2 before cleaning:
Roomba 2 after cleaning:
Oh, i 1st time clean after almost a year! not that bad, imo. :D
thewiseone
Fun right?? Practise makes perfect, after a few times, it becomes a piece of cake to disassemble and re-assemble Roomba! :D
hq83
the behind part i always got problem..
the bin become very tight after i re assemble back..
disassemble 2 roomba .. both oso like tat.
ronnie
I got mine (Scooba) from ebay about a year back. When registering with Irobot, I put in "gift". Maybe you could try that.
thewiseone
Never encountered this issue b4. Was yr bin ever dismantled. Suggest u check the fittings when puting back, never force... the clips should snap in place... else alignment may be out.
hq83
hmm.. dunno..
dun see anything wrong anywhere. everything fit back nicely. but when slotting back the bin, can feel its very tight. bit everything still work.
yes i did dismantle my bin. but dun tink its the problem. cos got this tight feeling even b4 i disassemble the roomba.
mosmos
never dare to open up, i always use a small long brush thru opening holes, to brush dust out yellow area. :s22:
thewiseone
Ah ha... so u've dismantled yr bin b4 eh? Well, i faced the same problem b4. I took apart the bin and found the cause. There's the section of the impeller housing that u close in snuggly with the cover. Sometimes the !@#$@ electrical cable to the motor may get in the way. If u r not careful, the bin can still be reassembled but u'll find it tight to fit the bin into the bot later on.
hmm.. dunno..
hq83
but i got this problem before i dismantle my bin.
mayb i will dismantle everything next week end to check..
