iRobot Scooba experience
XxDrAg0nxX
Ok did something simple...
I stuck 2 wooden chopsticks into the hole in front :D
Marked off the floor level and snip it off...
Hope it works :D
UMMmm could the sensors be those 2 holes plugged by the chopsticks? :D
thewiseone
The 2 sticks should not be affecting the sensors, anyway i've marked the sensors with a red circle each ...
dankoo
Just a qns...you guys still leave the roomba to be charge 24x7 or off the charger after like 3hrs? I tried to off the charger but it seems that the batt do not hold the charge very well....
mosmos
High Honorary Member
:o i just charge it for abt 3.5hrs then turnoff, did not really time how long it last.
hq83
starting after i got the roomba, i switch if off after charging.
but dunno y after a few weeks, the docking station have some problem. it wont charge the roomba anymore. and they send me a new docking station.
after tat, i dont turn off the charger anymore. charging it 24/7
thewiseone
Unless u dont use yr Roomba daily, u r better off leaving it on the charger 24/7. Mine has auto scheduling so i leave it 24/7. Also, bear in mind that NiMh cells have relatively high self discharge. If u leave it off the charger too long, it may not have sufficient capacity for the next cleaning cycle. This is not like Scooba where u leave the battery on external charger 24/7 will greatly shorten the lifespan of the batt.
jc777
i dont leave it on charger 24x7. usually i will charge it a day or so before i need to use it. then used liao, leave it there until next time i need then charge again. realise that it does not hold charge well, so didnt want to fully charge and leave it at that state.
XxDrAg0nxX
Yeap.. it was dirty alright :D
GOT 8 sensors, use cotton bud to clean...
Hope it works fine now :D
thewiseone
So hows your blackie now after cleaning? Hope its working fine ..:D
BTW, anyone knows what happened to Roomba review forum? Looks like its been down for the past week ... :s27:
mosmos
:o no it has not been down, always working.
i think they are banning overseas ip or whatever, you try to access with proxy or without proxy then can access.
For me, i have to use singnet proxy to access. :o
ktee
I can still access it thou.
Btw, mosmos, did u receive ur scooba? My woot roomba via bdx juz reached my doorsteps at 12:25pm. :D
mosmos
:( there's a delivery notice from DHL yesterday, i called them and asked to deliver again tonight.
not sure whether it's scooba, because it's from dhl. :s22:
XxDrAg0nxX
Not say down la... its like always tio stuck :D
Let me go test now since i am free :D
