iRobot Scooba experience
molecule
I wouldn't use scooba on my parquet.
Use Roomba on parquet, u'll be pleased with the result.
on the contrary, i think scooba is ok for sealed floors like parquet. if the quality of laying and sealing is good, the floor should be flat and smooth enough tat not much dampness remains like what happens with tiled floors.
even if still damp, sealed floors should not allow the water to seep in and warp the wood. it is laminate floors which have to be very careful. i always make sure to run through with a dry 3M mop to absorb as much water as possible
Normally I let the fan run while running the scooba, so the water dry up faster on parquet.
dankoo
I use the fan to hasten the drying too. However as mine is old flooring (!14 yrs) so I take caution with sccoba....I still use it but not that often for that room.
doremifa
When you apply the code, the total will change and reflect the promo price and google checkout will take that price....anyway, that code expired...you can check out roombareview. People there will alert if there are promo codes.
please help!
after I filled in shipping address(comgateway address) @google checkout @irobot website, the billing address (country field) automatically changed to US, can't edit.
what shall i do?
TIA! :(
mosmos
High Honorary Member
please help!
what shall i do?
TIA! :(
:s11: does not face this problem last time.
btw did you use any discount code? not sure whether there's any now. :o
mosmos
nope, no discount code applied.
wonder if irobot only accepts US credit card now? errrrrr...:(
:s22: try to order with usa billing address, see if the order can process thru'
btw which model did you ordered?
doremifa
have tried filling in Singapore address in the billing address field previously but with standard checkout. the order was accepted by irobot, but got an email 2 days later and was told my order has been cancelled, w/o any reason stated.
i'm afraid the result will be the same. so lazy to try again, errrrr...
i ordered roomba 560.
mosmos
you can try to order from amazon.com same price with free shipping. :o
http://www.amazon.com/iRobot-560-Ro...1?ie=UTF8&s=home-garden&qid=1218772092&sr=8-1
try to use this discount code in amazon.com to save $20.
Save $20 when you spend $100 or more on Home & Garden and pay with Bill Me Later® Enter promo code BMLHOME1. Subject to credit approval. Offer limited to Home & Garden items sold by Amazon.com. One per customer Enter code BMLHOMEI at checkout. Here's how (restrictions apply)
doremifa
thanks!
didn't try amazon initially because read the review that sometimes amazon packing list different from irobot, now think bopian.
found this in the link you attached, so cheap! too bad we can't buy.
http://www.abcvacuumwarehouse.com/morevacdetails.asp?DBID=2017&ID=iRobot+Roomba+560+Robotic+Vacuum
mosmos
Recently read some negative reviews on the roomba vacuums. Some questions for you all who own the 500 series roomba.
  • Is it true that the side brushes are fragile? ie. they can snap off easily
  • Battery life, does it have inconsistent run times?
hansolo76sg
running through with a dry mop is nowhere near tiring as actual mopping since im not pushing down hard at all.
anyways i take this as a chance to touchup the edges to the wall which is the only shortcoming of the irobots and that is it doesnt do edge and corners well
waliew, then it defeat the purpose liaoz....double work leh.
hansolo76sg
hansolo76sg
from my experience with amazon so far, only loose items will end up in their external box which is irritatingly quite alot bigger then required.
i bought my scooba from amazon and it arrived in its original cardboard box with its edges taped like crazy. :s13:
i guess amazon will have an external box for their purchase?
wah your site still selling scooba 5900. :s22:
DigDub
Where have? Would like to see the demo first if can :D
as what mosmos said, they have the roombas and the scoobas at the upper cross street office. vivocity best denki on weekdays got roomba display with a person there to show the demo. weekends at courts tampines.
