iRobot Scooba experience
thewiseone
The rest of the retailers are selling Scoobas at a significantly higher price... only Scooba 340 HSN is the most value-buy. However, it seems like they are out of stock now. They were almost running out when i ordered (through a friend) mine last week. :s22:
Sad to hear that.:( Now it is officially blocked by HSN. Boys and girls, say goodbye to order from HSN unless u hv fren in US. This makes mosmos one of the last to be able to order fr hsn.
Order fr Amazon, they are more ex but everything run smooth, so far.
mosmos
High Honorary Member
ktee
very risky to smoke them like this! When the actual package arrives and the external invoice/packing list shows 'battery', game over instantly! :eek:
Yup! You are rite. I dont want to take the risk. :o I email stoosi to ship to my bdx address. Hopefully they allow, else will need to take risk liao. :(
finrodfl
Believe the Scooba Clorox is pH neutral for a purpose. The floor cleaner Clorox on the other hand has a pH between 8 - 11 !!!
Does that mean that this floor cleaner isnt safe to be used on the Scooba/?
ziggyy
:s11: they don;t shipped to CWG now?
Yup, check out the email i got from them, on page 328....I've even sent them a link to this page to tell them there's a reasonable market in Singapore and to reconsider;)
mosmos
Hooted 1 pc. GOOD DEAL! NEW set. My reman 5800 fr Amazon cost 149 w/o the rubber mat.
But the HSN is better... too bad cant buy.
:s22:
but this 5806 looks like last time hsn.com 5800 model with extra virtual wall + scooba mat.
mosmos
tis one can u other than clorox liquild? i meant those tat kan buy at our local shores...
5800 can use tap water.
Hope not so suay to have 5900 parts inside, since it's not remanufactured one. :crazy:
Only the power supply is diff, using 110v, you need to buy a 220v-110v transformer with 100w power at hardware store for abt sgd$25
croc1977
not tap water...any other liquid can use on tis...considering now...water how to clean oil stain...
mosmos
you can use any cleaning solution you like.
though from last few past few posts, use 1 with ph neutral would not hurt the scooba pump.
thewiseone
Thats correct as far as pH level goes... this is rated between 8 to 11. In addition, the composition is also different though it smells similar. Cant say for sure unless u want to be the guinea pig to test it out. :D
Demiurgestar
Hmmm anyone have an extra scooba 340 charger to sell? or anyone know if there is anywhere i can buy a replacement for the charger?
