now trying on contact lens...
i choosed 3 pair daily for trial...
after tried 2 pairs, i notice tht e vision is not v clear as compare to when i m wearing spec n wear liao got slight headaches...
so i went back to check with them...
she told me tht maybe my eyes might be too dry n advise me to try on bi weekly...
now wearing biweekly acuvue oasys, it seem like e vision is not v clear as compare to my spec...
is it normal or i not suitable to wear contact lens?
do u all hav e same problem as me?
hmm she talking through her ass manafter trying bi weekly, it also not as sharp n clear as wearing spec...
i went back ask, she say nothing wrong with e degree...
she told me as spec is farther away from eye as contact lens is stick to eye, tht y..
n maybe my eye is dry..
contact lens nearer eyes = sharper vision.. unless it's so sharp until become blur, like magnifying glass.. but can't be.
got a feeling that brand not suitable for you. just change brand
your sight is it blur when you just put on ur contact?
after a while, it will be okay.
After the blur has gone, I find it clearer than my specs.
I also got this problem with Acuvue Oasys.
I called the optican, she said it is normal. (especially my degree is high)
Anyone also got this problem?
no.. is all e way blur...
i using e same as urs for bi weekly...
got diff contact lens for diff eyeball "shape" one issit? cos i tried contact lens, wear not much problem, but take off is very difficult, like stuck on my eye like that. so i stopped wearing. the other day i went to another shop, i brought up to the boss, and he say is because they gave me wrong type of contact lens...![]()
hmmm sounds like a technique problem. What i do is use two fingers and place them at the edges of the lens, gripping it SLIGHTLY, then blink your eye.. sure to come out
