Show off your Springboard !
gabrielworld
Hey guys please help me!!!
I use the cydia to download the mac keyboard and the black IU into my winterboard.
After tt i go into winterboard to check it and hoping to c my black keyboard and blck IU but then nuthing came out.
Only in cydia then i can c the black keyboard and as for the black navigation bar, when i load into my text the black bar was there for a few sec before it turn back to the orginal one.
Any Idea why?
I even download and ssh and change permission but cant.
ZhuTou!
Any Idea why?
some theme will overwrite them.
u try go back to original theme and see if ur new download can be seen or not.
Mr__GB
Any Idea why?
the problem should not be lying in permissions. winterboard has this priority list whereby it will apply the settings of the 1st theme's stuff 1st, and the rest of the themes that u clicked will NEVER overwrite the previous themes.
could it be this problem?
gabrielworld
No ar..
I unclick my theme then i click those add on but then it never came out.
In the past i had the RM Dailer with the theme but then i realise after i add the Mod calendar into my lockscreen , this happen. Even the come with it winterboard Balck Navigation Bar cant used le..
Anyone had tis issue?
byteyou
actually do you guys think that those homescreen widgets come close to intelliscreen? I feel that intelliscreen is much better
Errz
intelliscreen buggy.. and its always get updated. lol new version just out
if the feature suits u. its useful.
Mr__GB
the updates is... to prevent ppl who are using their crack intelliscreen i suppose, as crack versions do not allows free upgrades. other den intelliscreen it is laggy too.
there is one tihng i like alot abt intelliscreen is the smartdial, pretty useful! dun needa unlock to make calls
Mr__GB
No ar..
how abt u show us ur print screen? i tink tt will help in my understanding.
Errz
lol no lah.. the freq update is not just for cracker
intelliScreen for the iPhone Release Notes
Version 2.27 Enhancements:
QuickView Enable/Disable Control
Improved Performance
IntelliScreen button when hidden
Persist alerts until you clear them (in case iPhone battery dies, IS restarts, etc).
Version 2.27 Bug Fixes:
Sometimes IS causes iPhone screen to not dim
In certain layouts, IS can cover up slide-to-unlock
Difficult swipe to hide/show IS
Sometimes, doubletapping to IS2 may hide IS
Performance improvement for Alert View animation
Date label mis-aligned
When calendar set to Upcoming Day/Week, may not update daily
Screen dims when using iPod controls
Weather Label may not show
Version 2.27 Known Issues:
Mail may not always mark as read (work around - mark read 2x)
Launching Mail from IS will only take you to the mail account - not the specific email
its like. 2-3 weeks 1 update. good and bad bah. at least they trying to fix the problem (which wonder why they dont test run it properly first , like this bug "Date label mis-aligned")
falcon212
guys... this thread is for "Show off your SpringBoard" please keep the thread clean :p thanks
TonyStark
ok here's mine:
no questions will be entertained :D
Mr__GB
i wouldnt agree more tt intelliscreen needa work on their codes :p
under intelialerts
SMS Privacy (Premium/Trial only)
You can disable Apple's SMS message popup (containing the message) by enabling SMS privacy. This will allow you to use your phone and not be interrupted by a message.
ZhuTou!
No ar..
Like that uninstall the mod calender lo...
waynerooney
guys i realized that some themes doesnt allow you to change anything else from it. for example the wallpaper, sliders, dialer etc. i thought the 'User Wallpaper' would work but it doesnt. any idea how to change them?
ZhuTou!
u can change them thru ssh...
provided u know to change it :D
itachisama
if u wanna use the user wallpaper instead of the theme wp. just drag the userwallpaper on top of the theme name. how to drag just tap on the 3bars thing and drag it up. :) if u cant understand this just google it for more info.
