DNS-323 Network Storage
alpc
Does anyone tried using the USB printer port? Can I attach something other than printer to that usb port??? Am trying to see if I could use this port to sync my Centro to my PC which has vista 64bit - means cannot use usb on PC to sync!
richneo
apparently the failure is almost certain, it's just a matter of time.
so updating f/w might be a way to avoid bricking the HDD
of course, there is news that the f/w that seagate released earlier might not be the correct f/w
*sigh* can't believe this, DNS 323 is a great NAS system but marred by the HDD.
why would dns-323 be marred by the hdd in the first place
dns-323 functions the way it was designed.. if the harddisk manufacturer created a faulty harddisk, just change the harddisk and dns-323 will still function the way it should be
quekky
i'm using seagate 1.5TB with no problem
richneo your seagate also no problem right?
richneo
yup
after reading all the horror stories about bricing the seagate harddisk, i better dun touch it since its performing perfectly
ricard
sorry, misscommunicated.
i was referring to my personal system. I like the NAS ssytem with DNS323, juz that my whole experience is marred by this HDD debacle..
yup. I agree with you, it's nothing to do with DNS-323
el_leumas
there's no hd in the dns-323 right? its just a standalone box when you purchase so you must purchase the hd separately right?
richneo
you need to have either 1 or 2 peices of sata ii 3.5" hdd inserted before it can function
el_leumas
just asking, can u install games into the hard disks if you are using dns-323? will it have any effect on the game-loading speed etc?
btw, anyone wants to let go of their DNS-323? feel like getting 1 to play with :D
travirjir
anyone knows which file to edit for transmission such that when the download is completed, it will move the torrent and the file to a folder of my choice and also delete the resume file. Thanks
Lss
transmisison doesnt offer such a fuction on commandline. the only way to do that would be to use crontab and a script.
travirjir
what would be the name of the file? <something>.crontab? and where should the file be saved at?
I'm assuming that your ,
default download folder is /mnt/HD_a2/torrents ,
and the torrent files are stored at /mnt/HD_a2/.transmission/torrents
and the resume file is at /mnt/HD_a2/.transmission/resume yes?
WooHoo
Hmm anyone here tried the new 1.06 firmware?
Have tried upgrade it but have some issue here.. Keep having this when i try to login
Access Error: Site or Page Not Found
when trying to obtain /web/login.asp?id=2428868
Cannot open URL
This only happen when the NAS running about 30mins..
Anyone here facing this problem too?
mun_hoe
i've no issues for the past 3 weeks on 1.06 firmware......
maybe the IP settings are back to default, why not try popping in the setup CD and detect the drive?
WooHoo
Hmm i can access my drive when first boot tho, just that after awhile i can't login anymore, the above error shown up..
Btw did you do any reset after the firmware upgrade? Theres no reset button for dns-323 right? i did a software reset using the web login tho.
Oh ya i still can access my network drive normally, just that i can't login to the web interface..
mun_hoe
there IS a reset button at the back, just use a paperclip wire to poke and hold for 8 seconds and the power LED will flash to initiate bootup
if after reset still fail........i dunnoe liao :(
