Yunnnn
- Oct 22, 2007
I don't mind lah personallyBut like I say, if you are a subsidised patient, then you might get different docs... I think its kind of hard everytime you see different docs and you got to keep explaining your situation all the time...
Private one more expensive, but then again, at least the doc will be able to track your progress...
~ Anyway that's the treatment you get at Polyclinics all the time, though you can request for specific doctors, I usually don't.They can check your records on the computer system anyway...and if need to clarify then clarify lor
