breitling81
- Nov 13, 2001
Ok bro, so its boleh to do the following ahz:
1. bath with ointment / oil bath / etc
2. tap the skin dry after bath
3. apply the steroid cream on affected area only
4. once skin appears to be dry, apply moisturizer.
You mentioned cannot suka suka apply, you mean the steriod right?
Moisturizer, should be ok to apply whenever its dry. Am I right to say that bro?
Dieting is important, but keeping the skin in its good and hygenic state is also very critical.
So many things to take care of.
I will be trying out using tonight ba after i finish work at 8pm:
1. Dermaveen shower and bath oil for bath
2. Sebamed moisturzing body lotion
**** no pharmacy near my place. Must go amk hub...
Bingo. your points are all correct..
Ya, steriod cream dont anyhow suka suka apply but i know once itch sets in, we will use it no matter what..
Once skin tears, chances of bacteria infection is always there thus inflammation and reddish. Thus need to be clean and stay clear from dust, mildew etc. Wah.. kana those its Hallelujah..
Shower with whatever doc prescribed shower wash you are given or so then the bath oil.. Pat dry then use sebamed lotion after out from shower..
but dont do too often as it will hurt the skin
