The Power Supply Chart
ultragt
Hi,
based on current rig --->
can my OCZ PowerStream 520 give enough juice if say upgrade my gfx to 9800GTX+ for example? Or should I upgrade the PSU to a much better efficiency one first??
Thanks!
cktandrew
Hi, can i check if the CM Centurion 5 or 534 comes with power supply? If not, which power supplies are suitable? Mainly a budget unit just for secondary student so not meant for heavy use. thanks!
ashray99923
i have local company xtech (450w)....and now i am going to buy palit hd4850.....should i buy a another local company psu of 450w???.can i use them together??
Ray1026
yes, it is not comes with PSU...I suggest u can buy Extreme 460W or 500W PSU for ur comouter,
beano
hi folks, i don't see ANTEC on sale anymore, which is the next best PSU in line?
uRiZEn
Hi,
lookin to get the Cooler Master UCP 700W PSU as i think my Epower Xscale 600W PSU might be consuming too much power and it's time to jump onto the green bandwagon.
However do u think 700W is too much for my current rig?
I was actually lookin to get the Enermax revolution 85+ but couldn't find it for sale anywhere.:)
Or shd i even consider changing the PSU?I am in front of my comp practically more than 12hrs a day gaming/surfing/doing work etc.
alpc
Between Andyson F650W and Enermax Modu82+ 625W and Cooler Master Silent Pro 700W... which is more efficient? which is more quiet?
dashtan
Hi fellow HWZ members,
i am using intel core 2 duo 8400,gigabyte EP43-DS3L,Palit HD4850,Kingston 2*2gb ram,Seagate 500gb,Samsung 22x DVD writer,CM5...can a Andyson 500w meet the requirement for the psu of this rig? Thanks in advance!!!
Ray1026
it seems a old version comparsion.:s11:
I bought Cooler Master Silent Pro 600W PSU..the efficiency is85% and modular PSU...I think it is good enough for my PC and Silent lah......:yawn:
stanff11
Which PSU would you guys recommend for 1k watts? Was thinking of these fews>
1. Antec quattro TPQ
2. Ikonik vulcan
3. Corsair HX power
4. Silverstone SST-OP1000E
Any others?
Gregko
what do u guys recommend for 600w to 700w category?
budget is between $180 to $250.
20% 50% 100% would prefer it to be more than 82%
