iRobot Scooba experience
ziggyy
Just bought a convertor which converts 220V to 120V. crossing my fingers that it works...
thewiseone
She doesnt appear to know what she's talking abt. There is an acceptable voltage tolerance in AC supply and unless your Newstar convertor is damaged or under sized, it should work just fine.
Hi all,
Spoke to a nice lady at Homefix and was told that the Newstar convertor cannot work with the irobot charger. My charger states input 120VAC, 33W, 0.6A & output 22VDC 1.25A and the newstar convertor is only 220v to 110v. Electrical applications was my worse subject during poly so i'll believe her.
Is there anywhere i can buy a convertor for 240v to 120v? Or what will i need to charge the robot (assuming the earlier charges using the newstar convertor hasn't spoil anything yet)
Thanks.
Edit: Found this online: http://www.cableuniverse.co.uk/catalog/cables/step-down-voltage-convertor-240v-120v-100w-max.html
Anywhere in Singapore have something like this, the homefix branch i went didn't have it then. Can someone who is better at electrical stuff confirm that 110v & 120v does make a difference, used to think it'll just take more time for the charging... Thanks.
ziggyy
Thanks bro. Can't complain too much, that's what I get for skipping too many classes...
Trying out a 72hour charge with the new convertor and if it doesn't work, left the battery/robot itself...
ktee
For those interested to get a bargain roomba or scooba, woot is having a woot-off now. Try your luck but must wait loh. =:p Woot accept sg credit card or paypal.
www.woot.com
boluilang
My roomba discovery 4210 finally uplorry.... seems like the main brush motor cannot spin anymore.
It has been with me since 2005. Cost of repairing may be up to $80.
Now I wondering if I should get the new 500 series roomba, or repair the roomba. :(
mosmos
High Honorary Member
get a new one maybe costing less than sgd$200. Wait for woot.com offer. :o
boluilang
I thinking of getting a recon one, so that i can also have spares parts in case roomba goes crazy again...
dunno when woot will offer, by then, my floor would be full of dust.
anyone wants to sell their spoilt/rarely use roomba?
Flex11
hey.. so based on the comments, can i say that the roomba is good and able to clean the house effotlessly without me doin anything except to on it ?
mosmos
yes you can, but you still need to cclean or empty roomba bin every week. :o
bakasa2002
Just got another 535 shipped to me last night. About 8+ kg, bloody ex. Realise CGW is quite an expensive way to ship with the insurance and taxes. Not as gd as last time. Any better forwarder?
ziggyy
Mine was BL, $50+.
Still can't get mine to work even with a new step-down transformer. Anyone can lend me their battery or charger? Or help me charge it? Trying to figure out if its battery or the APS charger spoil...
jc777
Mine was BL, $50+.
where do you stay?
pinkiez
Transformer
I got the NF-230 Newstar transformer for my scooba 380 & roomba 580.
Problem is that I can only charge one at a time. I was wondering if I could charge both simultaneously? If so, how do I go about doing that?
Has anyone done that before?
Thanks in advance!
mosmos
Thanks in advance!
:s11: buy a 2 pin multi plug socket?
thewiseone
Whats the capacity rating for NF-230? Is it 230W? If it is, then it's more than enough to support both a Scooba and a Roomba together.
so a NF-230 can support 2 machines at one time? pardon me as I'm quite dumb when it comes to electricity.
