controller
- Nov 15, 2003
Just had my aircon changed last friday by Gaincity. Bought the Toshiba system 3 non inverter.
How much is your Toshiba Sys3 non inverter from GC?
Tazzi80, thks for sharing..
Unfortunately, my aircon is not cold anymore (has gas leakage) and suspect due to the old trunking. So, mine will be very messy, need to tear open all the trunking/piping
- Which toshiba model did you get and how much?
- Did GC ask you to replace the metal bracket as well? (they told me must change?)
- Sign up for the extended warranty also?
if carrier is gd, than u wil c alot of ppl using carrier in your block..I need to change my old LG aircon as well.
Why no one is recommending Carrier here? is it ok or not?
I was shopping yesterday and one salesman was strongly recommending Carrier to me.
Not sure what model, but Sys3 non inverter @ $1650 (inc installation, no bracket). He claimed that Carrier still has 2 motors in the compressor while LG/Dalkin has one (for non inverter).
I asked about the Samsung Sys3 non-inverter @$1399 and he claimed that the compressor is china made. no good. at least LG @1550 is still thai made.
I am planning to visit Gaincity and see if there is some good deals.
Any advice from you guys is much appreciated.
mayb u try to put the unit higher?Hi anyone have a 9k btu portable aircon can share your experience? i bought a trends unit and its not working in my small attachment room after hdb upgrading of size about 3 by 3 metre (approx 90sqf).
The is absoutely no difference from the air temp outside the room even after leaving the unit on for like 5 hours..
Called the company and the guy told me i must blow the unit at myself? i was thinking why the hell i spent 400 bucks on a aircon that needs to blow at myself...
ZZzz please give some advise or opnion..
THanks
single split/system 1?I'm so glad I found this thread. I'm from Malaysia and I presume models available in Singapore should be available in Malaysia as well, for the most at least.
I'm in search for incredible silent units only. I've run down my list to Hitachi, Mitsubishi, Daikin. Indoor units should be 23dB or less, outdoor units should be 50dB or less. I'm very fussy. 1HP/1.5HP would do, to be honest, I'm not really sure how to determine what HP I need.
Can anybody give some recommendation, and specify models too please.
Trunking and piping different ah, i change all my pipings but use back my old trunking. The trunking is just the plastic cover for all the pipings.
There's only 1 Toshiba non inverter model (The one with 3 ticks). 1850 is the price i paid, no bracket. Comes with installation and change of pipings. If no change pipings 1.7k.
I got a ledge, so not very sure about the bracket.
1850 with change of pipings and installation.
Notice that the price of the toshiba sys 3 has increased to 2129 with default installation and piping @ GC AMK. Upgrade to armflex 1/2" and copper 23 to 22 cost 180. the self clean function is really very gd in terms of long usage.. as in it wil not grow mould inside which wil causes bad smell when on aircon..Anyway very happy with the Toshiba aircon, already very cold at 25degree. Then there's dunno what self clean function where the internal fan would continue to blow for some time to dry up the internal after you switch off the aircon.
