hmm..not bad!
type of copper pipe? G22, G23?
btw do take pic of your installation!![]()
Upgrade of Copper 23 to 22.. for sys 3. costing $60/-... is Copper 22 better than Copper 23? don't really know...
hmm..not bad!
hmm..not bad!
ya..G22 is better than G23 as the thickness is thicker.not yet install... coming to my house to install 2 weeks later... after the lunar 7th month... will try to take some pic then,..
ya..G22 is better than G23 as the thickness is thicker. but in this case, G23 is enough liao.
ok..![]()
how come been chop?argh... been chop!!
they like say mine is R410 for the refrigerant... the gas travel at below 0 degree... so advise me to get upgrade for pipe to last longer.
Any one has any recommendations for buying lights, e.g. ceilings lights for my living room, my three bed-rooms, my kitchen, also the dimmer lights for my false ceilings??
The contractor broght my wife and I to the so-called "affiliated" lights shops at Balestier Road... Prices not very attractive, I was hoping to look for a third opinion from another light shop. I only know Tai Yong near Selegie Road...
Thanks in advance.![]()
The whole stretch of balestier road are mostly lightings shops, you can take a walk there or go renotalk dot com to seek reviews. One of the most popular shop highlighted there is lightings dot com dot sg but seems like no delivery. Prices shown on website seems to be cheap. I gotten mine from Dreamz Lights opp of shaw plaza, sales & delivery svcs are good, i got my own electrician to install.
Hi, jtec14,
Thanks very much for your advices.
I always find light shops along Blastier Road a bit on the expensive side. Even when my ID brought me to their "so-called" affiliated two light shops and one sanitary shop at Blastier, which "so-called" offer a 10% discount and the shops will absorb the GST, the price of the sanitary products like rain shower set, taps, stove + hood, kitchen sink, etc... are more expensive than another shop (which I purchased the items) near to Selegie, the two-storey shopping center.
Ok, maybe I will drop renotalk dot com and your recommendation of Dreamz Lights to see see look look.
Thanks for your advices once again.
Cheers.![]()
No prob, just sharing. Along the balestier stretch, not all are expensive. I got my Cuizino Hob + Cuizino hood + Franke kitchen sink + Franke mixer tap package at Excel Asia (mainly sanitaryware), services also not bad, look for Desmond, quite a knowledgable and flexible guy as i changed one of the package item with topup although other staff are rather stiff about it.
Btw the correct name for the lightshop is Dreams Lights at 317 Balestier Rd.
Anyway got to bargain hard at all shops if you buying a lot of items. This is what I learnt while going through my reno.![]()
Scrapped my 5 year old McQuay system 4 and replaced with a Mitsubishi Heavy Industry system 3 this May. So far so good. No complains.
By the way McQuay been taken over by Daikin.
MHI sys 3 was in my mind too... when did you bought it?
S.M. at GC initially intro this MHI sys 3 to me.. around 2800 plus too...
then when i went to another GC, another S.M told me they received a quite a few complaints on sounds like pss pss sounds dunnno from the sys or the A/c pipe.... can you share if there is any such psss psss sounds?
and intro me to Hitachi... (malaysia made)....
however, Me ended up getting Toshiba... cause all the 3 brands (ME/ MHI and Toshiba), after calculating... M.E used up more $ in electricity than MHI and Toshiba...
Bought in 12th May. Installed on 25th May.
I have not heard any sounds from the pipe, but will moniter.
The original price was $2499. I paid $100 more to upgrade to a system 4 compressor with 3 blowers.
The electric bill dropped 40% as compared to the McQuay inverter.
Your aircon outdoor unit sit on ledge or s/s bracket?
If no need bracket, $3k is a bit on the high side.
OIC, so the final price paid is $2599 (including gst)?, from GC?
BTW what is the BTU for your sys 4 compressor?
and the btu for your FCU?
did you do any upgrade of pipe?
i just installed 2 units of s/split of Panasonic a/c, CS-C9JKZW(CU-C9JKZ). However at 24deg, the air is cooling, but not cold. is that normal? does it need time to warm up or smtg?
