Air conditioning - Any recommendations please??
steven0608
the above Daikin uses R22, thus cheaper, yet lesser maintenance n problem. now R410 still very exp in terms of gas itself. so would recommend using R22 system now.. although the total price is abit exp, but i tink its worth it. Daikin only makes aircon, i believe it shld be better than other manufacturer. not sure wats others opinion..
Hi,
Just know that G...C give and $150 less of $2799 and also free $200 NTUC voucher so net net is $2499. They provide G22 copper pipe with 3/4" insulation for Mit Heavy Ind sys 3 inverter.
As compared to Daikin sys 3 R22 inverter, it is an saving of $500.
So bro, is Mit Heavy Industrial OK ?
Please advice.
chunlianghere
Hi,
Please advice.
wow..not bad!
yup..tat is gd. u can search in this thread. i remember there is gd things about MHI.
mikezuper
I have the same sentiment with chunlianghere on Daikin aircon, thats why I choose Daikin :)
Using sys-3 non-inverter for my bedrooms and sys-1 inverter for my living room.
steven0608
Hi,
Me too! R22 Daikin is still the best. My thinking is that whichever system running at higher pressure (r410a is 1.5 times higher than r22), it tends to leak more easily in joints if not installed properly so installers play a major role in the durability of the system.
If Daikin can give $200 ntuc voucher, then I don't mind re-consider this :) $500 different is a lot. For my case, I still need to pay $660 for cutting hole at false ceiling for piping...
Unless I dont change piping which I believe this is not recommended since it is already 10 years old piping.
tellim
just purchased a MHI inverter system 3 aircon from Best Tech w extended warranty purchased.
going to scrap my 10yr old National aircon. Actually 2 units are working ok except the one in master room not cooling properly (due to daily usage) so decided to change all.
hope the installation will be good. heard good and bad things about Best Tech To be fair, other coys have their bad installations too. just pray mine will be ok.
Mugen
Whats the total cost for the MHI sys? thks!
tellim
$2600 inclusive $250 added for extended warranty. price also includes service vouchor, light vouchor given by them.
Mugen
Yours quite a good price...
I just bought mine at GC...
MHI sys 3 = $2699 free $200 NTUC voucher
Upgrade to Armaflex 1/2" and copper 22 with 16mm drain pipe = $180
Add 2 yrs service contract = $350
Extend to 5 yrs warranty = $359
S/S bracket = $150
Trade-In old sys 3 = -$150
Total = $3588 :(
tellim
the service vouchor given i think is $150, lighting vouchor only $50.
purchase was done by my father. dont think we upgrade anything on the wiring neither any trade-in.
let me check receipt at home later bah? but confirm less than ur amt.
thesingingbard
Hi,
i assumed your old piping was running R22? If you change to R410a, then you'll have no choice but to change your piping.
since you've oredi decided on R22 Daikin... you do have a choice of re-using the old pipes... =:p
steven0608
Hi,
Yes, I can re-use my old piping BUT I believed my piping is leaking since I needed to top-up gas every year and many said that the leak will get worse as time come by. Furthermore, GC only discount like $150 for not laying new piping assuming I am using Daikin R22 inverter.
After serious consideration for whole 2 weeks, I decided to change piping. So if piping needs to change, then I have more choices. I can use either R22 or r410a. Then MHI is the cheapest running on r410a.
This is my case.
chunlianghere
Hi,
This is my case.
provided if your new piping is thicker which also can use for r410..
so wonder wat is your new aircon spec? :s8:
navarro_t
that time my auntie went to a shop in yishun ave 5...think the price not bad...:p
steven0608
Hi,
Here it is :
Mit Heavy Indust sys 3 inverter r410a
SCM60ZG-S (25590BTU) compressor
SKM28ZG-S X2 (9553 BTU FAN UNIT)
SKM35ZG-S X1 (12000 BTU FAN UNIT)
Cost $2799
minus $150 trade-in old air cond
minus $200 NTUC voucher
Total net $2499 with GST with the following upgrade:
G22 copper pipe
3/4" Armouflo insulator
used back old drainage pipe because consealed inside wall
Good deal ?
I prepare to buy 5 years extended warranty so + $399
total $2848
chunlianghere
Hi,
Here it is :
Cost $2799
G22 copper pipe
Good deal ?
total $2848
wa..u use so thick insulation? :s8: later your trucking might be very big...
steven0608
Haaa....this is what the saleman said. i have not seemed the sale agreement yet so let see if he is just boosting....will pay deposit only when everything is stated in black and white properly.
All piping will be hiden inside the false ceiling so should be ok....bigger means better ? If they have 1", i also put...:)
chunlianghere
haha... no point putting so thick la..:s13:
later i tink they will hav problem putting it in false ceiling..
thesingingbard
wahahaha... :s13:
you're the only 2nd fella i know who uses 3/4" insulator and even wanted 1" if they have it! :s13: The other person was me! =:p
anyhow, just to let you know... 3/4" could be an over-kill, but i'm not regretting. Hee... =:p
btw, if you're hiding the pipes inside false ceiling... then I would be kia-su also and use thicker insulator... just to reduce any little chance of sweating which may become very messy for your false ceiling! =:p
steven0608
wahahaha... :s13:
Hi,
we same tune :s22:
Any hope everything go well on the installation on next Monday. I will update pros and cons of GC if any.
To be frank with you, I have no confident on them fixing back my false ceiling perfectly as original because they are not professional in this area....still worry now...
Should I just changed the air-con with the piping ?? should I ?:look:
Then I will back Daikin R22 sys 3 inverter.
still worry bros.....kids exams in 2 weeks time so if the installation was screw-up, then nightmare leow.
