Mobile Broadband User Testimonials
  • Need help?
    Reach out to someone from Samaritans of Singapore (24 hours): Call 1-767 or WhatsApp 9151-1767 More info
czheyuan
Think M1 still having the promo for a fixed price for unlimited data in HK.
Received the SMS when I was in HK previously.
Yup they still having thru their worldwide Vodafone partnership. $15/day for unlimited data on Smartone Vodafone network in HK..
buzzmario
It works fine. I'm using ubuntu with Prolink PHS300 and Huawei E220.
hi, last night i try it with my acer one with hua wei e169, still cannot work, google around also cant found the answer. any web link for guide?
thanks
YorYor
I'm not so sure all modems will work out of the box on Ubuntu. With my ZTE K3565-Z, the modem doesn't get picked up by NetworkManager and I have to manually configure wvdial to get connected.
It's a non-trivial process, but you should be able to find the necessary steps through Google.
Perhaps you might have more luck with Karmic Koala once it's released.
ct
Starhub also have this type of plan with some roaming parther.But $30 cap per day.
YorYor
I would think it's cheaper to just get the local telco's prepaid SIM card. Not sure about HK, but Thailand's Unlimited GPRS/EDGE (though much slower than 3G) is only about $2.5 for 24 hours (DTAC).
Anyway, back to the main purpose of the thread. SingTel's BBoM customers, come share some reviews! I'm still waiting to hear from those on 4Mbps and above plans.
ktee
M'sia also has BBOM rental. Celc0m daily rate is RM6, weekly is RM20. Speed is only 394kb & data is unlimited. But you need to hv a modem to fit the SIM card or can buy in MY (up to 1mb/s) at around RM200.
Wonder how they recoup the fee of RM6 (24-hour) if they give you a SIM card & usage?
TS, after so many pages, perhaps it is time to consolidate and give us a 'bird-eye' view of which telco is best at which area... It wld be v useful for those who is deciding to sign up BBOM. :D
YorYor
Wah, so many estates, how to consolidate! Anyway, there really aren't enough reviews yet... there are only a handful of SingTel reviews, wouldn't be fair to them to say they aren't good in certain areas.
liangtam
384kbps is PHY rate. Actual rate after overhead and errors are much lower.
BTW, COL over in some parts of truly asia~ is comparable to SG, but other area definitely lower mah, if you compare basic necessities. The price is right in the mind of their main customers.
YorYor
Anyway, the SIM card won't be free.
Considering the cheapest 1Mbps package at $22+ after GST without discount, that works out to be about $0.75 per day. On a contract.
And just look at the daily rates for adhoc subscribers... M1's $18 for 3 days is it?
stephen30
This is my connection speed. I am using M1 mobile broadband, 2Mbps. Testing the speed at Hougang Ave 8 area. Time was 2.05am.
1. Provider : M1
2. Plan : M1 Mobile Broadband 2Mbps
3. Area used : Hougang Ave 8
4. Max speed attained : At least 1Mbps and above...
5. Rating (1-10) : 8
6. SpeedTest link : See above.
7. Others : Nil...
Hi threadstarter, pls update and thanks. :)
YorYor
First AMK testimonial! Hehehe... Punggol/Sengkang also missing from the list... no one using mobile broadband in those estates? Or too much concrete (and too ulu) for good reception?
cyberian
I may be in Punggol tonight. If I'm there, I'll do a test...... after my crab meal.. heee... heeeee..... :D
Asus80
M1 2Mbps ang mo kio Ave 10
Signal full bar M1 Base stations @ 542 amk Ave10
YorYor
Thanks guys, more or less covering most of the bigger estates.
Anyone tried on Sentosa, Pulau Ubin, Pulau Tekong?
cyberian
Starhub 7.2Mbps Prepaid
Tampines St 42
2300hrs
Starhub speed really bad.
Test againg at 1000hrs, speed still the same. Did a ping test and looks good. Wonder why?
http://www.pingtest.net]
