When I was at Taoyuan airport yesterday, the rate was 23.17.
AirAsia lands at T1. There are 2 money changers both before and after you clear immigration. You can wait till you clear immigration cos the rates are similar. Just check out all of them for the best rates.
Yup. I changed at Mega ICBC which has outlets both before and after immigration. Both have identical rates.Thanks outlander,
so you change after you clear immigration?
Hi,
May I know what time does the money changing counter at TaoYuan Airport closed? I am taking Jetstar so will reach after 7pm+ on Saturday. Will the money changer counter still be available??
so little???i changed at shingkong 1 shopping center top floor only 22.02 few days back
so little???
sg can change up to 23 liao![]()
from the trend i belief the rates will still go up..at least till the eve of tw elections wic is early decwhere to get 23? wan to change also le. Thinking whether to change now or wait first as only go taiwan end of dec 09. Would u think the rate may increase again?
what is the rate at Kaohsiung airport?
