Stats time!
Skwat79
Bwt: 68 - 69 kg (67.5 kg weight class)
SQ: 130 kg (no belt), 135 kg (w/ belt)
BP: 72.5 kg
DL: 145 kg
Total: 352.5 kg
FattyRabbits
when you lift your back was not straight... your form was bad
All 1RM forms of DL are bad. If you can DL the weight with good form, that's not your 1RM. Regardless of back straight or not, when you lock out, that's a successful DL.
kebinu
That's just one of the many definitions.
Coach w* based it on good form. :D
kazekagi
i wouldn't wana sacrifice my backbone to have a higher 1RM. what do i really get from a higher 1RM? recognition?
Shaderer
New to lifting here.. Extremely weak :S Currently on Rippetoe's.
BW - 70 kg
Bench - 45 kg x 5
Back Squat - 60 kg x 5
Deadlift - 80 kg x 5
zencro
BW - 70 kg
Bench - 45 kg x 5
hi shaderer, how long have you been lifting?
btw, do you guys include the weight of the bar when you post your stats?
ketua
No need to include if your bar (carbon fiber? titanium alloy?) weighs less than 2kg.
Note:
The standard olympic barbell (where the 2 collars at both end can spin type) weighs 20kg == 45lb
