Official Carrier Settings for both STARHUB & M1 (Cellular Data Network Accessible)
JeNoVa-IcHiGo
Carrier Settings for both STARHUB & M1 (Cellular Data Network Accessible)(Winnie The Pooh Logo ^^)
Hi all,
Posting Official Carrier Settings for Both M1 and Starhub, and both with Cellular Data network Editable..
*Original one Cellular Data Network is not editable cause the option would not be there*
The Files here have been edited ONLY to make cellular data network accessible.
Preview of Winnie the Pooh Logo on M1 ^^
File Folder :
http://www.mediafire.com/IPCCfilesFORm1SH
**Update ON 12/12/09 : Updated and tested all settings in folder. It's all working**
**UPdate : Operator IPCC with logo added, same folder**
Credits to : Musashi in http://forums.hardwarezone.com.sg/showthread.php?t=2406701 for the logos :)
Download your relavant IPCC files.
IMPORTANT : Enable Carrier Testing First. Refer to
http://forums.hardwarezone.com.sg/showpost.php?p=42346569&postcount=23
Note : The Test.cmd inside is to enable CARRIER testing. Do download and run it if you have not enabled Carrier Testing.
Windows
Download and Run Test.cmd if you have not Enabled Carrier Testing.
Usage for the File.
1)Plug in iPhone
2)Under iTunes
3)Go "Devices.."
4)Under Summary Tab.
5)Press Shift Button then Click Restore.
6)Under Pop-up Window, Change File Type to "Carrier configuration(*.ipcc)"
7)Select the ipcc.
Done.
A&Fitch
Thank you Jenova! I am waiting for this IPCC so that when u are away from Singapore, i can edit it prevent from auto roam charges & secondly allow my kid to play it offline when in town. It is very wise for M1 & SH to have the Cellular Data network uneditable.
Thanks again, Good Job!
ychhcy
cant change the "file type" in itunes :s11:
using a ST phone on M1 line tho
match80
Hi,
when i tried to do that, it prompt for *.ipsw files. cannot find *.ipcc files.
Anyone have any idea on this?
skylab
so updated the carrier settings, official tethering for starhub is now enabled on the iphone.
but can someone show me how to enable the mms settings?
it seems to have disappeared!!!
aptget
what are the benefits ??? i'm still scratching my head
ychhcy
those who have no data plan and wish to switch off 3G data access will be able to do so. if yuo had updated carrier settings via itunes, you will no longer have the option to edit the cellular network data settings
match80
yup, it happened to mine also. even the starhub logo is gone.
coxmod
Thanks Jenova! Possible to add the logo version? :) I missed my M1 with the logo ipcc ;)
skylab
reset your iphone, n you'll get both tethering and mms, group sms and everything.
only thing missing is the option to enter the carrier settings, don't know why that is removed.
stephan
The easy way out is to use iphone browser...
Browse to User\Library\Carrier Bundle.bundle and replace the 2 *.png. files.
The logo should be resided in User\Library\Carrier Bundle\ if you have the ipcc with logo installed before this official ipcc....
medotcom
For those who did not have data plan, once the carrier is update, as some of you know the APN setting is gone. No more adding user name and password. Your GPRS is auto log in when WiFi is not in used. Check your data usage.....some new NOs is adding all the way....:eek:
IceLatte
Hmm. Using app like sbsettings for "Edge Off" can still prevent data usage right? no wonder they bundled 12gb data for iphone users taking iphone plans.
anyway, max capped is now $30 according to some source.
correct me if i'm wrong. cheers
match80
sorry, but how do u manage to gt to the folder? is it in the iphone or in the iTunes folder.
ltchew
anyone kind enough to explain the diff btwn these 2 files vs the offical one from itune?
stephan
i updated the official carrier setting, my fake apn profile still intake...
My GPRS and Edge data is still disable, no different after update...
Only changes is I am able to access internet tethering setting....
