Adams peanut butter.
RabbitKing
Hi guys, recently just bought a jar of adams peanut butter, first time buyer, it seems that after i mixed the oil in together it is more watery than skippy. ( e brand i normally buy ) and it tastes also somewhat different than skippy, has a wierd aftertaste..
is it normal that e adam peanut butter is like this, particularly, the watery part.. :/
nicekit
not watery lar
but more smoother
cuz this one is u mix one
there's another ADAM is pre-mixed version
pre-mixed version usually is dried one...
allwellendswell
Put in the fridge after stirring.
It does not have a wierd taste.
RabbitKing
So its like that one ah? Ok lo, like too oily for me le.. Lol the taste also wierd wierd one.. :s
edit: i already put in fridge le, i dono how to describe the taste but abit different from skippy..
FattyRabbits
It will be weird if it taste the same as skippy. Adams is 100% natural(added salt if salted). Skippy is alot of sugar and other nonsense inside one.
addict951
High Honorary Member
Adams better lah, with the oil
Wah piang, Skippy, dry like ****.
Anyway, NTUC got boh? Woodlands here sibei lousy leh. Civic, 888 and Woodgrove all dun have! :s27: Then the exorbitant CS at cwp is charging 6.15 per bottle!
galapogos
Moderator
Moderator
Skippy is the one with the "weird" taste. You've just been conditioned to it, so you don't think it's weird.
FattyRabbits
I also staying at woodlands. I think the nearest is AMK hub, the NTUC at basement got adam's, i go there buy one.
Paper_Dragon
Really? I live in Serangoon and thought all nearby marts don't have. Not even the one at Bishan. Guess it's time to check out AMK hub. :D
cowculator
Joo Chiat complex I just bought for $4.25. Have been buying at Cold storage for 50% more all these years. :s27: Pain in the ass to stir.
Carrefour has the freshly grounded ones as well.
Aiberu
bro, stir after you left in room temperature for an hour.
cfm much easier.
Cheers
bonkerz100
I've tried both the Adams one and the freshly ground ones from Carrefour. I think that the one from Carrefour taste much better.. and it's 100% ground nuts and nothing else. :)
grm203
how about peter pan peanut butter?Been eating that one for quite sometime already
neonone
Actually the only thing other than cost and taste that should be of concern is whether it contains hydrogenated oil aka Trans fats. Read the label.
cowculator
I also find the carrefour one better but it cannot keep as long.
cfm much easier.
Cheers
thanks for the tip.
FattyRabbits
Every Carrefour got? Or only certain ones? Any carrefour near woodlands got? How about CWP's carrefour?
Know_me_Well
bros out there.. i was just at the ntuc at civic centre woodlands.. they have adams peanut butter.. you can find them along the same isle as rice milk.. 4.95 a bottle..
