IBM ThinkPad Users' Group
greenbeam1980
The CD Key on the COA of your laptop should work if you decide to install from scratch.
Hi, can list down or pm me the detail steps? I need to change my 32-bit Home Premium to 64-bit Home Premium. Some ppl tell me need to change to better OS. Now very confused. Please help me.
Mine is W510 w/o any image. Thanks in advance.
shawn_sboi
If you got a iso image you got from online and do a clean install. You can choose between 32bit and 64bit. :) i can confirm it. Cause on my win vista i can select between those 2.
naruto13
the link have total of 6 iso from what i see, win7 home premium 32 n 64, ulti 32 n 64, pro 32 n 64.
but each diff package will have different key right i presume.
thanks though.
shawn_sboi
thanks though.
Can i have the link though? As i'm not sure what you talking about. Okay if you got a ISO image you downloaded. Retail ISO. You can choose between 32bit/64bit. That's what i am referring.
Do not be confuse about the key, example if you got a home premium with 32bit, it is also supported in 64bit. Need clarification here! Expert. This one i assumed only.cause i remember this is the case.
naruto13
ok pmed.
i understand what u mean, each version can install in either 32/64.
i meant let say cd key for home premium can be used in ulti or not etc. but i doubt so lah. only those who tested or know the loophole then can ans.
cscs3
just to add on wat kenshin is replying. the first 4 digits its ur machine type, the next 3 is the sub-model. and yes. if u happen to buy extension warranty. make sure to check the details. is ur warranty upgrade by us (service center) or by the reseller. meaning after our system detects ur machine is out of warranty, but if a customer claims to have extended the warranty with the shop, it means u have to contact the shop. i have a case last year, a customer bought a SL400 from i think harvey (iirc). he bought extension of warranty from there. but my system checked it is only 1 year standard carry in warranty. but he got i think 2 yrs extended. so after checking, his additional 2 yrs is not covered by us, but by his reseller... so guys out there i hope this helps in preventing u from coming up & down; making urself frustrated too. lastly, i will try my best in any problems u face to my ability. have fun using the thinkpad.
Actually, this bring up a very good point. Never never buy a extended warranty from reseller or 3rd party. This is just a insurance ant not warranty. The person sell you the insurance take a cut from it. You PC do not necessary go back to same brand of service center when you get into trouble.
Sometime you may not even get the insurace (warranty) after few years as they have closed down. You never get a case with CASE for this type of situation.
naruto13
hmm in this case, what about thinkpad warranty which is offered by juzz1 with 1yr additional for this yr fair?
webstop
As far as I know, you need specific 32-bit or 64-bit ISO for Windows 7.
Direct links here: http://www.mydigitallife.info/2009/...links-ultimate-professional-and-home-premium/
feintan
why the big hoo haa between 32 64 bit win7, you will not notice any difference for end user unless you are running 64 bit program also. if you are using a 64 bit OS and running 32 bit software like Flash games from fb 32 bit Browser which you will since there's no 64 bit flash. 32 bit 3d games it will not use any memory above 3 gb too. at the end of the day also lppl.
ginseng1
Just go and buy 64 bit Windows 7 loh...
Acad version only $99 for business and $129 for ultimate
If you are not acad, buy OEM version loh...
ahtea
Please drop me a PM. I will get back to you shortly. Have been rather busy recently.
dasanyuan
is someone looking for me? weekend family day, bo eng reply here. do u guys need help in clarification or something?
just oot, go devils! great win against the "kop"
naruto13
yeah we do need u. we need check the juzz1 lenovo warranty for poly fair.
do u know? cos we not certain the so called 4th yr warranty is directly upgraded to ur side or what, but still thanks for ur help. anyway to find out ?
dasanyuan
ur machine type serial number?
