Razer Users Official Thread...
mizumi
Hi all,
using a razer mamba myself, currently my razer docking station can only charge my mouse whenever my pc is turned on, just wanna check with other fellow mamba users, does ur docking station charge ur mouse when ur pc is off, but however ur psu switch and main power switch is still on
because if it doesn't then i wonder when then i will be able to have time to charge my mouse as the moment i turn on my pc i'll be using it, can other mamba users or dennis verify this so that i can check whether am i the only one facing this problem, thanks
Doesn't charge when the pc is off.
StriGoi
Guys, need to ask y'all an important question. Does your razer copperhead have this squeaking sound when you right click it?
I wonder if warranty covers that. It's very annoying.
Thanks
denniszz
Hi all,
Some motherboards support USB charging while PC is off with Power Switch on from the wall socket.
StriGoi
Denniszz, need to ask you an important question. Does your razer copperhead have this squeaking sound when you right click it?
Thanks
RyuShinEX
my copperhead is still going strong!
btw using exactmat - the double sided one with wrist-rest will spoil my mouse's feet ah?
and is the wrist rest comfortable for you all?
and how to know if exactmat is wearing off?
StanII
so it's due to my motherboard limitation? because i dont have time to charge my mamba unless i leave my com on..
ZiXianG84
Hi there,
May I know how am I going to know my Mamba is fully charge? I have it charging for coming to 5 hours and the charging bar is still charging. Is it normal? Normally how long it will take to fully charge a Mamba?
StanII
Hi there,
make sure ur mamba mouse is off before u charge instead of leaving it at on which may cause it to charge fully then drain away power and start charging again..
ZiXianG84
I always have it switch off when charging. If I placed the mouse at the docking station, the charging indicator will rise from Bar one to Bar three and then continue the process. If the Mamba is fully charged, how will it displayed? All three bar indicators will light up together?
ceecookie
currently using a 2 years old worn-out deathadder
should i ditch it for a cheaper abyssus?
If your hands are big(and fits the deathadder well), i recommend against the abyssus as that mouse is quite small and may not be comfortable if you are used to the DA's ergo :)
FapFapAhBoy
what about imperator? cos my DA condition quite cui alr, the bottom material abit scraped off and all the dirt trapped in the buttons are bloody disgusting, use needle also can't remove all
also, wanted to ask what's the main diff between exactmat & vespula?
is there any big diff?
mizumi
Yeap. All the bars will light up and stay that way. Usually takes about 3-4 hours to fully charge even when I'm using it.
ceecookie
Im sorry but i do not know much about the mentioned products. What i told you regarding DA was quoted verbatim from Razer SG when i wanted to order Abyssus.
For a guide you can refer to the technical dimension here. The Imperator appears to be marginally smaller(-0.5cm) than the DA so it should be fine.
StriGoi
"W" Button Faulty
Guys, iam using a razer lycosa mirror edition keyboard and last night my "W" button wasn't working at all, all of a sudden.
Rebooted my cpu THAN only the "W" button is functioning.
Deniss.. is that covered under warranty?.
My lycosa is only 2 months old!
Please help.!
Thanks.
StanII
bro, does ur docing station still charge ur mamba when com if off?
denniszz
Please help.!
Thanks.
you check if this is frequent, if so, you may bring down for RMA. :)
StriGoi
Ok will monitor, thanks for the reply.
But you have not reply to my previous one.
Razer copper head mouse just bout also 3months back has this "squeaking" sound each time i use the right click button.....
It's very annoying actually.
Can i send it down?
Thanks.
StriGoi
Can i send it down?
Thanks.
Ok confirm its frequent
