Anybody got problems with your Nook hanging, not responding....mine hang need to take out batt but no screw driver with me now... Haiz..
ok...i super duper kancheong now.....checked with vpost and was told that Speedpost will deliver today. *** biting nails..***
Any 1st steps to do once I have the nook in my hands?
I know the info is in this thread but just want a quick guide.
slowly admire the hard casing that kept the nook and charge the nook...
Damn... nothing works.. my Nook just freeze up....wat should i do now.
seems serious...i took out the batt, and replace le. not working
seems serious...
maybe u can try this method which i found from the net:
http://bookclubs.barnesandnoble.com...-It-s-getting-on-my-nerves/td-p/468577/page/7
I was thinking of connecting the nook to the PC, register it, transfer my books from My eBook Library in B&N and then play with till batt is completely drained. Thereafter, I will charge it.
The link by loretta is helpful. I encountered before and the method provided by support staff of B&N is the same. Normally take out battery and put back would solve thou. Its some sort of residue charge issue if not wrong.
Tuakong : Welcome to the club!
I think it could be that my batt is drained... even though it is indicated 26% charged on my Nook. Cos the last time I charge it was when I 1st received my Nook and that was like last thurs or Fri....
Hope it works... wish me luck.
Good luck! Do keep us updated (asp. moi)......![]()
