greenbeam1980
- Nov 23, 2004
I only did a system backup last sun.
Wah, your battery still under warranty or not?Aiyah, mine is like 45% wear after just 100 cycles. Bad battery!
Is it very persistent? Frequent BSOD is a sign of hardware issues... i suggest you call up Lenovo/IBM service centre.
Any guys can answer the previous questions?
This issue is somewhat technical, hope u guys can help.
I have this thinkpad edge. I am using a main pc to control a few laptops/pcs using Win2Vnc. The main PC is using standard 102 keyboard.
However it seems that my thinkpad is using non-standard keyboard.
The problem is that the ctrl click I send via Win2Vnc from my main pc (using standard keyboard) to the Thinkpad is not recognized. The ctrl clicked is recognized when used on other laptops and pcs.
Thanks alot for reading.
Dasanyuan
Basically it is like this.
I use another PC (Master) to remote control my Thinkpad (Remote). However when I try to send the Ctrl button via the Master, the Remote cannot register the keyboard action. All other buttons such as A - Z, shift, space etc are ok.
It seems that the thinkpad Ctrl button is different from a normal keyboard.
Dasanyuan
Hi all the tech gurus out there, i need some help here.
My wife's T60's touchpad and trackpoint suddenly died and cannot use.
I tried to use the keyboard to go and access the settings, but it seems that they have not been disabled (set at automatic).
so how? what is the next step? is this a hardware problem? Cos her keyboard also has a stuck key...
Thanks in advance![]()
Hi, I have difficulty ejecting my Starhub 3G dongle from my X201 after usage. It does not prompt me that it is safe to remove. Does anyone experience the same problem?
