Hi, can anyone tell me your current firmware version that comes from SingTel?
Isn't every set is on 2.1 regardless of telcos?
I'm using version 1.26.707.1
I read there is 1.31 WWE asia out. Thinking of whether to upgrade.
Ahh. software number ah? My singtel set is on 1.31.707.1
Mine is 1.31.707.2 - Singtel set.
No idea, but b4 buying a Legend, check to see if the Home button is loose or not, a lot are having these problem.
reception problems don't disappear magically...it's more a case of the users getting used to it.gotcha! will be getting the Legend in less than 2 weeks on recontract...
mmm X10 tempting me. but my pocket is screaming noooooooooooooooooooo!
so no more people having issues with the reception?
via "legal" way, no, at least not yet from the rumours.btw andriods appls can be install onto memorycard or oly on the phones ram onky?
Your answer is already there..
WCDMA = 3G/3.5G/HSPA....![]()
Thanks~
Btw, do you have any prob accessing the wireless@sg using the Seamless and Secure Access SSA? I downloaded the manual but what they stated is not in the options of the legend.
Thanks~
