HTC Legend
Conan1986
Settings -> Sound & Display -> Animation -> All animations
that doesn't enable live wallpaper.. I don't think HTC has made the Legend to support live wallpaper by default.. so far only Android phones with 1Ghz processors have that..
Beefsteak
Ok i found that that the legend does not come with live wallpaper , but i also heard that live wallpapers can be ported over to the legend if your set is rooted..
kennyg1969
Live wallpaper is a battery drainer. Nice to have. I never use live wall paper when I had the N1.
Blobby
You need to root your phone in order to run live wallpaper. I have seen Hero with live wallpaper before.
kennyboy
Hehe...one guy post without checking the facts, and everyone pounces on him.... :D
It's like a wild jungle here. :D
waterballoon
Becos it is too early. It will drop when another set comes out to replace the legend. Maybe when wildfire is out otherwise it will not happen on the next 6 months.
Aish that's unfortunate... was hoping the Desire would push the price of the Legend down =.="
Roxy
Thought of getting it....but is 2GB enough ? iPhone minimum oready 8GB.
cyc1op
2GB??? as in SD Card?
You can get a 16GB sd card and you cannot install apps into the sd card until you root the phone
Is the on-board RAM and ROM sufficient to install new apps and games? Will there be problems like Samsung Jet where you'll get memory full after installing a few widget?
Pardon the stupid question, I'm still thinking whether to step into Android world.
kennyg1969
Legend has about 130mb of space left. Should be sufficient for quite a few apps. That is one of the issue with Android OS. The OS takes quite a huge chunk of space up.
