IBM ThinkPad Users' Group
dasanyuan
both T410/W510 belongs to huge n heavy. lol w is insane. so bloody heavy. got budget? no budget T400s for u. haha if not just get T410. its the best value thinkpad i guess for the moment. if not get edge. i think edge's pretty cool. :s13:
dasanyuan
Any Thinkpad users who just purchased their lappy at Republic Polytechnic recently?
I purchased my W510 in march but till now my extended warranty is still not updated yet(still at 3 yrs).
Anyone has the same problem as me?
Has called up Juzz1 twice, they mentioned it takes Lenovo some time for the updating. 2 mths not enough for updating??
don't worry. it will be updated surely. alot of thinkpads leh in singapore. just keep ur POP for worst case scenarios. but relax. u should have onsite warranty right?
Kenshin79
Does anybody know when the x201 tablet multitouch will be available locally at retail shops?
mid or end June will have X201 Tablet WITHOUT multi-touch display.
worldwide having stocks issue due to serious lack of supply from intel for Core i7 low voltage CPU.
if you want multi-touch display, you must place deposit to order from the retailer. my side already placed order for 2 sets, no choice have to wait...
sirleleas
s
Are you using a T410s? I agree X301 is a looker, but no power lah. Still running on Core 2 Duo and no discrete graphics. Something which I need for my line of work, furthermore I tend to play games too...haha
I really cannot swallow the price lah...for that same amount, I can get a full-fledged W701 with 2 x HDD Raid, CUDA 96 bit discrete graphics + WWAN leh
greenbeam1980
Yes. Just feeling uncomfortable that all.
Btw, anyone has keyboard protector for w510? The type that fits nicely one.
shawn_sboi
Yes you can order the W510 skin at MO section. Buy the nanosilver kind. $20. The normal plastic doesn't fit nicely.
dasanyuan
dun put k/b protector la. like machiam typing on a condom... so uncomfy. hahaha. i'm using a T410 now. quite shiok to type... i5 up man. better than my own rig at home... lol get the W510 to play ur games. alot of customer from polys using that.
flanket
T410 Battery Life
Hi, anyone care to advice on the battery life (6 cells) of T410? I bought one witht the i5-540 CPU and it only last around 2hr for normal work (surfing, spreadsheet, ppt, NO movie). The Thinkclub ad mention can last 5hr which my don't even last half of what mention.
pravinuss
guys, my charger is now screwed. Is there a number i could call to get the quotation of a new charger for my W500 which is under warranty? The lenovo website numbers i call are super confusing.
gohkhm
From your Thinkvantage Power Manager, were you running on 'Maximum battery' or 'Maximum performance' ? A lot of other factors such as your Wifi, LCD brightness come to play as well. 5hrs seems unlikely for a 6-cell
ahtea
You got to configure the power manager settings correctly.
Dim down the display when on batteries and change CPU to adaptive/slower speed to see if it helps to improve the battery life.
gohkhm
Perhaps the fuse blew on the power plug? Try changing that on your part and see if it works. I have a feeling that the power adaptor is not covered in the warranty, perhaps dasanyuan or other members here can advise.
ahtea
You should be able to find a replacement at authorized Lenovo retailers in Funan eg.AddOn to get it (if you need it urgently).
I think AC Adaptors are warrantied for 1 year. You might want to confirm with Lenovo by calling up their help desk at 800-6011-343.
pravinuss
Nah, its my fault. Its actually the connector jack that is the problem. Alot of wear on the jack so it doesn't work but the adapter works fine. I don't want to claim it under warranty cause firstly it was my fault and secondly its more than a year already. I think i will go funan check it out. Thanks guys
shawn_sboi
haha! got different quality of k/b protector. the 9.90 one feel like typing on condom. LOL! i bought the nanosilver clearer and feel nothing. :) so it's okay.
ceecookie
My R400 have been facing this occasional issue whereby the laptop locks up by itself similar to a BSOD except that the screen always goes blank. Wireless/Bluetooth indicator also goes off.
Have to power cycle the laptop to recover.
Windows diagnose it as a BSOD. Details:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 18441
Extra information about the problem
BCCode: 19
BCP1: 0000000000000020
BCP2: FFFFFA8004743828
BCP3: FFFFFA8004744208
BCP4: 00000000059E5A00
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Is this symptoms to known hardware problems?
ahtea
Locale ID: 18441
BCCode: 19
Service Pack: 0_0
Product: 256_1
Did you install any new applications or tried to reformat?
ceecookie
Nope, it's happening very infrequently that's why i dont want to reformat.
If it's hardware issue i wish to fix it before it get worse :)
我要买GT-R!
Singapore English 800 6011 343 (Local number only)
+603 8315 6856 (DID)
8AM - 6:30PM
Monday - Friday
dskw
apologies if this is the wrong place to ask, but i want to get another hdd bracket for my s10 netbook, the one that seems to be made of really cheap metal. would you guys know any place where i can get it? im not sure if there is such a thing as "generic 2.5" hdd laptop bracket". TIA!
