IBM ThinkPad Users' Group
dasanyuan
apologies if this is the wrong place to ask, but i want to get another hdd bracket for my s10 netbook, the one that seems to be made of really cheap metal. would you guys know any place where i can get it? im not sure if there is such a thing as "generic 2.5" hdd laptop bracket". TIA!
yes its the wrong place. this is thinkpad users. s-10 not here :)
dasanyuan
My R400 have been facing this occasional issue whereby the laptop locks up by itself similar to a BSOD except that the screen always goes blank. Wireless/Bluetooth indicator also goes off.
Have to power cycle the laptop to recover.
Windows diagnose it as a BSOD. Details:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 18441
Extra information about the problem
BCCode: 19
BCP1: 0000000000000020
BCP2: FFFFFA8004743828
BCP3: FFFFFA8004744208
BCP4: 00000000059E5A00
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Is this symptoms to known hardware problems?
hmmm... change sys bd meh? :D
dasanyuan
You should be able to find a replacement at authorized Lenovo retailers in Funan eg.AddOn to get it (if you need it urgently).
I think AC Adaptors are warrantied for 1 year. You might want to confirm with Lenovo by calling up their help desk at 800-6011-343.
yes. its quite confusing because i also don't know unless i check ur machine type n serial number. but dun worry most sch users 3 yrs for everything + onsite... but nevertheless u can call n check with that number.
westwest1
Are technical support people over the phone trained properly??? Tough for them to resolve my issue. How to get proper help from???
westwest1
wat number u called? and wat is the issue with ur machine?
call this number 800 6011 343
Thats the number I always call for help when there is problem with my machine. But it seems this time round they know nothing about this machine at all and telling me SOP stuff to resolve issue which I have tried on my own before.
Did try down grade the faulty drivers for the wifi card. resolved 90% of the issue, but the wifi still DC at times. Weird issue.
The power manager is the worst. If you run on batt and plug in the AC, the screen will black out. Even if you up the brightness, its still black. Again the technical support have no solution for me.
The audio output from the docking station produced static noise. Again they do not know the solution. Demo this to the technical guy who came down, he also do not have a solution for my problem.
My Think vantage toolbox under 32bit OS can read the bios, not under the 64 bit. No one can give me a reason why also.
Where can I get help for all these problem I am facing now?
Epee
Hi, anyone care to advice on the battery life (6 cells) of T410? I bought one witht the i5-540 CPU and it only last around 2hr for normal work (surfing, spreadsheet, ppt, NO movie). The Thinkclub ad mention can last 5hr which my don't even last half of what mention.
You might want to create a custom profile under Power Manager. As a baseline, you might want to leave your T410 idle for about 10 seconds or so, and then see how much power it's consuming under your current profile. This number can be found under the 'Battery' tab under PM. Create your own profile and check the same number.
For the records, my profile on my x200 includes adaptive CPU, Passive Cooling, screen at 7 brightness, dim on 15 min idle, dim on login, shutdown etc, max power save on WiFi, PCI bus etc. I installed an Intel X25M recently, idle power consumption (reading web pages, PDF etc) can go below 8W but hovers between 8 - 9W, awesome. The 9cell battery indicates in excess of 9 hours run time. In case you're wondering, it is very usable under this setting.
And yes, the boot and shutdown and app launch is ridiculously fast with the X25M :D
westwest1
you are not alone... We both are facing this problem. Step one uninstall the power manager, it does help a bit.
emphasiz
same problems guys. i almost giving up on this laptop.
1st. usb ports giving me live current, changed motherboard, changed wwan card, not solve and i give up
2nd. battery life super short, 1.30hr, change battery + reformat, extended a to 2.15hr
3rd. laptop super unstable, cannot be with os cos i reformatted it already, always freezes and hardisk stop running
4th. everytime the tech guys comes for onsite to fix 1 thing, he spoils something else.
5th. till date 4 appt already, still not done.
4saken
anyone knows how to switch on the integrated camera? cant seem to find the software...
westwest1
I have the same problem on the T410 for the first few days.
What other problem do you have also???
I waiting for a chances to talk to their software engineer regarding all these software issue.
shawn_sboi
What model are you using? T410? okay i am using W510 and my USB also giving me live current... I do not know if this is normal but it doesn't bother me. 2nd, mine is fine. 3rd, mine is fine. 4th never call before.
so is USB port being live normal?
tangpx
hi, my recovery cd for the sl400 is damage and i know it can only create a set of recovery disk.
is there any way to recreate it again? if not possible, how do i get a recovery disk from?
thanks.;)
emphasiz
thanks.;)
the copy that you damaged was it from lenovo or you burned it yourself? if you have never burn before you can burn a copy from the windows
tangpx
i did burn myself. at first i was able to use it. after some time, the disc was not able to read. i did try to use other drive to read it and still the same thing.
so i confirm that the disc is damage.
