Air conditioning - Any recommendations please??
chunlianghere
Why not good? Reasons? :look:
I notice you are like a die-hard fan of mitsubishi, do you work for them? :s13:
tat person very weird lor.. nothing to do. :s13::s13:
2007 when I do up my own house, it was only 1800 all in, for sharp system 3..
knn, why electrical price will go up one? I thot always going down ?
the electricity price will drop when there is drop in oil price.
but weird leh, isnt singapore electricity powered by gas from indonesia?:s22:
cannotliao
anybody using this panasonic inverter aircon?
http://www.panasonic.com.sg/web/pid/8813/Spec
any comments on it?
if you going for Panasonic make sure your window height allow the compressor to go through. Panasonic out door unit is bigger and taller.
Mitsubishi unit size is 1 of the smallest in local market that why some people go for it simply because they dont have much choices due to the window.
audiovideo
:s13::s13:
and they will get a pleasant surprise and be glad that they were "forced" to buy a better aircon :s13::s13: .... and felt ashame for making a wrong choice in the first place to have selected panny :s13:
epigram
Hi Air con gurus! I need some urgent help on the following.
I just bought an apt and I intend to replace my existing air con systems as they are 8 years old. The current set up consists of a System 3 (Master room 12k BTU, Guest room 9k BTU, Study room 9k BTU) and a System 2(Living and Dinning room 12k BTU each).
My air con usage is typically daily (Master, Study rooms) and occasionally (Living/Dining/Guest rooms).
I arranged for 2 site inspections but both technicians proposed different configurations:
(A) Follow existing configuration, ie. 3 rooms (System 3) and Living/Dining (System 2). This technician reasoned that this configuration saves on servicing as (given my usage style) I need only to service more frequently on the outdoor unit of System 3 than outdoor unit of System 2.
(B) System 3 (Living 12k, Guest 9k, Study 9k), System 2 (Dining 12k, Master 12k). This technician reasoned that this configuration enables both outdoor units are more evenly utilised, which is better in the long run.
I'm indifferent to both but what do you think? Do both explanations above make sense? Or is there an optimum configuration not stated above?
Thanks so much! :)
Hi! I have the same dilemma.
Proposed set-up is
26k = 18k (living) + 9k (bed)
26k = 18k (master) + 9k (bed)
26k = 18k (dining) + 9k (study) + 9k (utility)
But this means using 2 outdoor units in the day (living+dining) and at night (master + 2 bed).
not sure if it would be better to use
36k = 18k (living) + 18k (dining)
36k = 18k (master) + 9k (bed) +9k (bed)
18k = 9k (study) + 9k (utility)
so that only 1 outdoor unit will be used at one time.
cannotliao
:s13::s13:
luckily..still able to get through. :o
miyamew
@cannotliao: u have any pics of ur aluminium brackets? how they mount it?
or is it that ur compressor sit on the AC ledge?
mine is old hdb 3N type... window slightly bigger than urs.. but mine dont have AC ledge for compressor...
chunlianghere
normally for 1 side window, got ac ledge.
for those old hdb no ac ledge, hav to install bracket. shld be additional $150 for the bracket.
miyamew
@chunlianghere: u have lobangs for gd deal that can allow installment plans?
looking for Single Split inverter :o budget is $1000-1200+/- with power point+installation+brackets
t258jgn
Deluxe Member
Decided to get ME non-inverter (seldom use) as cheaper & got purifier bla bla bla.
MH got no extra bla bla bla.......
So which dealer to get? Coolserve, Creation Aircon, Gain City or Aircon Designs?
Air-Con Refrigerant: R410A or R22?
miyamew
ermm may i know ur "seldom use" is how often u on it? like 4-6hrs a day?
t258jgn
Deluxe Member
We don't use everyday. Only when the nights are too hot to sleep. Even if I turn on will be 4~6hrs only. Usage: 60~90 days per year.
limster
hi, sorry if discussed before, i tried to search this thread for the answer.
I would like to get a system 4 for 4 rooms, when in fact, I will most likely only use 2 rooms at a time.
When I look at the system 4. These are the specs
Mitsubishi MX4BD26 , it's 7k+7k+6k+6k BTU
Daikin MA56EV1, it's 6k+6k+4k+4k BTU
My question is , if i only use 2 units of a system 4 at a time, will the cooling power go u to say 12+12k for the Mitsubishi and 10k+10k for the Daikin? Or is the cooling power fixed at 4k BTU for example, no matter how many wall units on at a time?
thanks
chunlianghere
thanks
in order to cool faster, the fcu must get around 9k btu from compressor.
for daikin ma56ev1, its btu is 20267. if all btu is 9k(ft25dvm), each fcu will get approximate 5066btu if all 4 fcu is switch on. so it might take a longer time compare to switch on 2 only.
so in yr case, u only switch on 2 unit most of the time, shldnt be a problem for daikin ma56ev1.
for mitsubishi, different liao, becos its btu is 36000, so all 4 fcu wil stil get 9000btu is switch on all at the same time. so cooling power will not lose out.
annai
Went around a few air con supplier querying about a new set of system 3 to replace existing. After much hunting, still went back to my last installer due to reasonable price and good workmanship. The lady boss , Mrs Ang is friendly and gives good advice. Settle for Mitsubishi Starmex Inverter 3 eventually, upgrade from LG non inverter currently using.
Twin City Air-Conditioning Engineering, Blk 9006 Tampines Street 93 #02-200. Tampines Industrial Park A Singapore 528840, (65) 6787 4642, (65) 6544 2191
Greatsolar
care to share the price?
Thanks
chunlianghere
than got workmanship warranty?
miyamew
hi guys, wondered if anyone read yesterday Strait Times:s11:
Courts having promotion for
Samsung Inverter Single Split
(ASV09ESLXXSS/ASV09ESLNXSS)
9000 or 8500 BTU i think
4 Ticks
$899 with 2yrs installation warranty + 5yrs extended warranty..
on the other hand i'm comtemplating this
Panasonic Inverter Single Split (CUS9KKZ/CSS9KKZW)
8530 BTU
4 Ticks
$1099
Other than Bukit Timah outlet, which other outlets have most aircon choices?
wanna do a comparison on the spot... so need more varieties as was told that ME no stock ... :(
cannotliao
for aircon i will pay more and go for jap brand than korea but the courts promotion samsung set bundle with the extra warranty with such a low price maybe can give a try but better confirm what the actual warranty coverage.
miyamew
i will buy Panasonic then :D
hmm wonder what else i miss out..
father's SP/PUB/Singtel and CS/SC bills
HDB house plan
my CPF statement (can login at courts later)
for max credit installment :s22:
