The Spectacles Thread.
iNETeVO
Yes, they do have it in Singapore. Price wise quite expensive :s13:
for Seiko 1.67 is normally under $200 for a long long time...
How's the price like for 1.74 and double aspheric 1.67? :D
There's also 1.74 transitions from Seiko...
aldric12
not very sure of their price as nowadays seldom ppl request for their lenses. :look:
iNETeVO
Swissflex
I was quoted $380 for a swissflex and together with 1.67 lens, it's over $600...
Is it expensive? I wonder if it's standard price throughout Singapore for Swissflex??
aldric12
If you say just swissflex =$380 that is VERY expensive :s13:. I ever saw one chain store ever had a swiss flex promotion @ $200 Swiss Flex + PC lens.
What lens did you ask for??
slashGNR
A few weeks ago at the Lens Men optical shop (Compass Point), I was quoted about $300 if I could recall, for a Swissflex frame with Essilor Airwear lens (single vision)
iNETeVO
yes checked out a shop in tampines.. and also another one in bedok...
both quoted me for half frame model for $380 for frame alone...
and with a 1.67 lens is in the $600 range... a 1.67 Nikon would be even more ex$...
aldric12
$600+ for a Swiss Flex that :s22:
Joelleyuan
Hi, i dunno what u mean by "for a long long time...."
Seiko 1.67 is never under $200 from any shops that i've ever visited. All quote
at least $350 - $400 AND ABOVE. so i dont even asked about it now since it's
over my budget.
Unless you can recommend a shop that offer Seiko 1.67 lens under $200, pls share~~~~~~
iNETeVO
over my budget.
There are few seiko models....
I've been using seiko 1.67 for more than 10yrs... and always it's under $200...
up till now... the most expensive quotation is $240.
Unless u are talking about double aspheric, it cannot be so expensive.
Seiko so far is good for me... tried other brands like AO, Hoya, Essilor and Hi-top.... dont like them.
Try tampines... most shops offer under $200 for doing lens alone for Seiko 1.67.
aldric12
over my budget.
Yes it's very true that Seiko 1.67 asp lens is around $200 or below.
aldric12
then where is cheaper?
Not to say this brand is not good, but for me i will not recommend swiss flex cos there quite alot of compliant so far from what i heard feed back from my patient who ever wear swiss flex. I mean it's up to individual on how do you take care. :s13:
I'm not sure where have promotion as Swiss Flex usually are Chain store which are mostly selling. Can try going around to look for it. :s13:
slashGNR
looking for zerorh+ 137 lter .
any one know where i can i find ?
I ever saw a few Zerorh+ sunglasses on display at an Optical shop called Blue Eye USA at City Square near Farrer Park MRT...but my last visit, I don't see any..maybe the shop always change the displays to show more variety...not sure if it have the model you want
Adios...
whatme
What are the problems? :D
