IBM ThinkPad Users' Group
westwest1
a bit of update of the system that went for servicing.
The loaner unit i am using now is very stable and so far no error, they will exchange this board with the faulty board that is on my system. thus I no need to test the system again when the new board arrive this week. they make arrangement to do the swap of the board this friday. all the security features are working as per normal on this board and i pretty happy with it. All the TVT software are working fine.
Finally can get back my own laptop because i cannot tahan WXGA screen resolution, damn er xin resolution sia. wondering why its still being sold.
ahtea
Congrats bro. Finally they managed to solve your issue.
dasanyuan
i recently had this case. cust bought a t410 but his max resolution is 1280 only... so he was saying how can his t410 lose to my set. which i was using at that time. t60 running on 1440 win7. and was comparing this n that n all the nonsense y boot up so slow and stuff when he's on a i5...
i advise consumers to really check on the specs when they buy from resellers... the fine details are always the most impt..
westwest1
you nv tell him pay lesser does not mean good spec. :s13:
ahtea
Wah. i5 still slow ah.... Advise him to upgrade his CPU at the service centre (throw in an i7 CPU). :D
dasanyuan
actually i also dint realise. coz i have to admit. i assumed all T410 is high spec. but then when i check the machine type... i realise that his one was the lowest of all specs.. so i think 1 cent 1 quality no matter wat. haha
westwest1
Bro. Actually the booting is really slow. That's why I change to intel 80gb g2 ssd. Cause the loan unit is running a hdd. It's actually quite slow. This new i5 system does not mean it's fast, because the hdd is really slow. His complain is true. Cause the system start up is same speed as my old t60
taimiyyah
Hi guys,
has anyone ever tried downgrading a T61(or any similar exp) Win Vista Business Edition to WinXP?
m thinking of doing so. Could u kindly recommend a shop or anyone who could do this, or should i go to Changi and get it down?
Thanks in advance.
cheers!
joe
ahtea
Hi guys,
Thanks in advance.
cheers!
joe
If I am not wrong, you can drop by the service centre and loan a set of WinXP recovery DVD and do it. Vista Business should come with downgrade rights to WinXP.
You might want to call their service centre at 1800-418-9933 to double confirm.
taimiyyah
Thanks bro!
just called em.
if loan d DVD, u can do it on yr own in their service centre for free.
If u want to ask their engineers to do it, its 30sgd if still under warranty.
if w/o warranty, its 30 + 75(labour).
To get them to do it, will take 3 working days.
Hope this info helps. :)
westwest1
Hi guys,
Thanks in advance.
cheers!
joe
i just helped my friend upgraded his T61 to win7 instead. The performances is so much better than his xp.
or u want u can go buy the xp disc from lenovo at $70++. better than reloading it at changi.
Lss
tried taking pictures but my handphone without autofocus isnt working.
anyway i ordered the antenna parts from usa, will install it myself.
will try my luck with the lcd again. I agree WXGA on 14 inch is horrible for work.
ahtea
Thanks bro!
just called em.
Yes, if you are technical enough, do it yourself.
