Random Photos Thread
indigo22
u all think i shud invest in a tripod or dry cabinet?
currently using a dry box
currently using a nikon tripod given by a kind edmw-er
ragnarok95
Senior Moderator
Senior Moderator
Im using a nikon tripod also.
I got a dry cabinet to house my cam too. :)
indigo22
hais i think maybe i go hoot dry cabi first? dunno yet waiting to listen to u guys de opinion..
how much you bought yours ah? ard the $110 price range ah for 30L?
qingtian
i'm considering getting a remote shutter too hehe
where will u be getting yours?
Eh me? I already have le.
I got mine Remote from this online shop.
Cheap and good, better than ah tiong brand =X
http://www.shuttercentral.com/store/index.php?act=viewCat&catId=13
What your budget?
It depend on do you use ur tripod so often.
If you are a active user u use dry box also headache, cos every time open up u will see ur hummity metering going up and u need to wait long for it to go down again. Very troublesome to control.
qingtian
eh.. recommend a avg good tripod ler..
max height abt 150cm and not so heavy and exp
Eh, what ur heaviest setup? Budget? Brand conscious bo?
Just saw u have a Nikon Tripod, I think u hoot a dry cabi first protect ur asset first. U also no need headache in control the humidty also.
CS got ppl sell dry cabinet I think cheaper...
I'm using AIPO 38L Digital dry cabinet at around $200, come with 5 years warranty. Is more exp as it is a digital dry cabinet.
Look here for more info:-
http://www.clubsnap.com/forums/showthread.php?t=716073
FD Trinitron
IMHO tripod & dry cabinet should buy a good one as these will continue to use for years no mater how many cams/lenses u upgrade in the future. :)
I got the DigiCabi 50L at $168 from Carrefour with 5%+5% rebate using POSB Everyday Card.
For tripod I got the Benro carbon fibre Travel Angel series, can't remember the model but it's the shortest folded length (339mm) and weighs abt 1kg. Upgraded the ball head to take Max 8kg load.
indigo22
this DigiCabi u got, ish digital dry cabinet?
indigo22
What your budget?
ya lo, i saw from photog thread, analog harder to control :/
think i'll get a digital one, somemore if i go NS i'll have a peace of mind lol
think i'll get a dry cabi first, for the time moment i'll use my tripod first hehe~
KayAge
post the image will do
no advertising allowed anywhere in HWZ forum
i was about to signup for your website but your advertising seriously puts me off :slant:
rehosted the image up for you
Oh hey... thks for reposting.
Does the ads really put people off???
Haha... I thought putting a little ads will help to maintain the website... 75% of the proceeds goes towards singapore children cancer society... tot was actucally doing a good deed!
hahaha... well nvm!
indigo22
hahaha... well nvm!
if you're doing a good deed, you can even consider PM-ing the mod to sticky it or something
PS: of cuz u need prove of the proceed going to the organization
FD Trinitron
For me will be length and weight. Looks good!!
Since max load is of lower concern to you, then this model fits you. :)
I've tried this tripod b4, it's a bit flimsy to me, it's only stable for dslr with kit lens or small pime lens, not recommneded to hold heavier telephoto lens.
The twist & turn design is unique & it's pretty fast to setup.
