hugoboss1621
- Jul 15, 2010
can anyone advice me what is the price to purchase Mitsubishi easy clean system 4 inverter so that would not get con by the air-con agents...
8800 is ok IMO, mine is only 8550 if i remember correctly
ur room (non-MBR) is just the same as mine...
www.coolserve.com.sgcan anyone advice me what is the price to purchase Mitsubishi easy clean system 4 inverter so that would not get con by the air-con agents...
Seems a bit overkill using 8800BTU .. but for inverter air con, i guess it is okay
Yep.. the room is same as yours.... i guess for inverter air con, it is okay to use higher BTU so that it reach part load state faster...
currently, my LG non aircon inverter use 20kWh every night for 2 Fan-Coil... last time it uses only 10-12 during rainy day.. and 20 is possible during hot day...
but from what i observer, my compressor didn't have "turn-on and turn-off" anymore.. it run whole night, cold or hot....
for a bedroom size..8800 is jus nice.
but if the room is like storeroom size, than 8800 is abit overkill.
I reckon this is the "official" airconditioning thread. Would like to ask if anyone thought aircon-ing the living room is useless? Will it cost a lot in your bill more if you aircon the living room + 1 bedroom for say, 20 days in a month?
so mine inverter with 8550BTU is just nice hor?
the salesman said my room requires 11000-12000BTU
i told him doesnt matter, even if it takes that extra 5mins to fully cool down my room
i said i got budget means i got budget.... canot afford means canot afford
now i've been using it every night w/o fail for like 9hrs and weekends on it even during day time....
i wonder how much the bill would be....
if mbr is bigger than other bedroom, would suggest ~12000btu. else ~9000btu is jus nice.
mine is not mbr thats why dont need such high BTU
make sure ur aircon BTU is not under power for ur room size, else it will take much longer to reach the set temperature, or even worst nvr reach....in that case, it defeats the purpose of inverter aircon, becos if ur room temperature cannot reach the set temperature, inverter cannot save u on the electricity...
wow..yr usage alot more than my non-inverter w/ 2 fan coil usage..
actually if u see our room size (12 sqm), 9000 btu is more than enough. 12000 btu is overkill... typical MBR size is more than 20 sqm.. then 12000 btu will make sense
btw, one of the room size that I plan to put is only 6 sqm.. so 8800 btu is definitely overkill
Yup its all within ur budget.. like my case, the salesman keep saying 11000 BTU is the preferred one, but i insist on my stand that i have a budget to follow..
and the most impt thing is whether u mind that to on the extra 5-10mins to cool ur whole room or not...... (BTU plays a big part here, other than budget)
Btw how often should i wash my filters?
It has been a month since installation....
new aircon can last longer.. you can take your time to clean it every 4-6 month. If you live in heavy traffic area (more dust), you have to clean it more often.
for daily usage, recommended to wash every 2 weeks. doesnt mean new one no need wash.
