ifile on iphone...
just do this.
Connect ur iphone to your house wifi.
hit the wifi icon in ifile..
now type in internet explorer/firefox. the ip address example 192.xxx.xx.xx:8080
yes... follow what ifiles show...
pes1989. don't get u... pic pls.
pes1989, it's simple.
go to the bundle>com.apple.TelephonyUI using ssh or whichever
EDIT! actually ah.. this just rename this bottombarknobgray-alt without the -alt.
if can't need rename all. to the black name. To trick the file system.
Done.
the theme file inside got transparent one. Got 2 kind. 1 is black and 1 is transparent. you should go check then try out.
Good question it's just a name to let the device identify... not sure how but that's what i know.
PES1989. i suggest just changing the names of the white to black name. that's all. will work ifnot wrong...
Why I have 2 files: bottombarknobred.png and bottombarknobred@2x.png?
the one with @2x i think is for those using iphone 4, winterboard will only use pics with @2x for iphone 4.
likewise, wihterboard uses pics without @2x for older gens.
to get rid of the black thing got a few methods.
1) if you have photoshop, you can try to erase the black area. (i think if you try in paint the background will turn white not transparent
2) you can also try to reduce the resolution of the pic with @2x to the resolution of the pic without the @2x. (i think you need to dl the inverted version to get the @2x version without the black background
imo this method easier but i not sure if it works in paint.
3) pm me you email and i'll send you the one without the black background, but you have to promise me you will upload it here so that ppl who wants wont ask me to send it to them![]()
pulsating meaning like flashing... from left to right... glowing flash light at her "slide to unlock" which i helped her to change the name.
yup, ask shawn already replied you, carrier i used makeitmine from cydia then you can basically enter whatever you want, including emoji
the pulsating slide to unlock means my slide to unlock is changed to '♥♥♥张信哲♥♥♥' and then there is a moving flashlight going from left to right![]()
Wow....you guys are damn great with all this stuff.
will have to crack my head doing all these.
cant ask too many questions.....wait kena blacklist.
Maybe if there is a IP4 meetup.....can meet you guys to see all your great stuff will be great.![]()
google is ur friend. heh.
