hyperpower
- May 2, 2006
my lockscreen
anyone knows how to change to tap to unlock?
my lockscreen
my lockscreen
my lockscreen
Managed to get the problem solved, thanks for your help anyway!
I will post the files w/o the black background probably tonight as promised.
Preview of my Lockscreen: http://plixi.com/p/43512261, http://plixi.com/p/43464623, http://plixi.com/p/43512543.
this 1 is tap to unlock. is called padlock tap to unlock. I just change the icons only.lolb3nzzz
nice lock slider... it's included in your themes one right?or custom slider from cydia.
look for slantedlock in cydia, the theme got weather script in it liao
the zip code for singapore is 1062617. need to edit the script and add this code to allow weather to work
how come i cant go sources add the file:// for mobilesafari??
bro . phewwwwwwww managed to edit the script via safari. must enter the upper caps s and low caps exactly sia........
ask u ha for the accuweather - u chooose this or yahooweather?
so for accuweather zip u enter 1062617?
how about icon set - HTC, tick, Klear - what thi?
thks alot
then set config? it said saved Null// ...
thks alot
i can't see the image?hyperpower can reupload?
Slantedlock is really ugly. really depends on user. Just tried it.. to me fail leh.
thks alot
