meaning still black screen?
INSTALLATION INSTRUCTIONS
You MUST follow these installation to make the theme work.
Theme will show BLACK SCREEN if these set up steps are not completed.
Theme requires:
"Winterboard"
"file:// for MobileSafari" module from Cydia(free)
"LockScreen Clock Hide" -- or any other plugin/module that hides the default clock.
1) Download and install "file:// for MobileSafari" from Cydia.
This will enable you to access the configuration screen.
2) Open Safari and type in this:
file:///Library/Themes/SlantedLock.theme/config.html
BOOKMARK this link so you can return to this page on Safari anytime to make configuration changes!
3) Enable SlantedLock in Winterboard. Now enjoy!
NOTE: It may take a few seconds to initialize on first time.
This set up is a tad confusing. However, you only need to do it once to benefit using the configuration with ease in the future.
http://forums.macrumors.com/showthread.php?t=1006066
after that, go to Photo apps and select the picture u want and set it as lock screen
it takes awhile for theme to work.
