yr miotv was on 2nd tel line?
Hey guys.. sidetrack a bit. I wanna sign up for Mio Sports. Can I sign up a mio tv plan if someone else residing in the same address has outstanding balances with singtel? Anyone working for Singtel here to help advise?
Thank you
yarh hor... 2wire can hor... try with 2wire also no problem.. change back to aztech got problem.. knnz... why are... liangtam got any idea why not? firmware latest also lei... vod nia problem... all the rest ok lei..![]()
2weeks nv pay bills ? they terminate ur line ?i was *gone* for 2 weeks lah
how to answer you, lol
my line became fully dead now after im back...
Thank you
2weeks nv pay bills ? they terminate ur line ?![]()
It was still a newly installed service leh, now I wan use cannot.
Eat into my free 1 mth of all avail channel liao(except sports)
2 weeks NS lah.
yup, rly died, no -48v even
and the worse part of the ordeal is the time needed for singtel to arrange for ppl come down![]()
wa...
so u got double check tat the line in yr hse n outside didnt break?
Didnt had time leh
Maybe later i go unsnap the dp and hook my own wire in.
i believe you are the resident expert on the 2wire modelneed some advice...if have 2 separate lines (2 X 2wire routers) for broadband (one per telephone number), can i someone link up the 2 networks together to share files?
eg. last time when i had only 1 line (1 2 wire router), can share files amongst all the PCs connected to the same router.
now if 2 separate routers on 2 separate tel lines, is there any way i can set them up to share files?
arigato gozaimasu![]()
Wrong thread to ask 2Wire/Filesharing qn leh
Anyway, can, set both the 2wire set to different subnet first, then link the 2 networks up by hooking a single utp wire from LAN-LAN
i.e. 1st LAN: 192.168.1.h/24, 2nd LAN: 192.168.2.h/24
hi bro & sisanybody sign up mio home ? and mio tv got what channels for mio home ? am now using mio plan next months my dad contract 2 yrs liao..
This message is sent from HWZ forums iPhone app
come with the mio movie channel.
