HTC Legend
foosoomin
p0is0n said:
btw foosoomin, when u flash 864mhz rom, ur phone hang on start up?
When i'm using 844Mhz, the phone does not hang on startup......
Some applications crashed, jammed or even couldn't start at all, so i gave up this kernel & used 825Mhz instead
foosoomin
p0is0n said:
yeah weird, we are using the same legend, but we don't have the same specs after rooting. how can it be? different batch got different specs that we won't be able to tell?
I agree with "kennyboy" on his Post #2283...
My phone performed poorly on Spanish ROM, but performed very well on Nightly Build
It must be related to some hardware compatibility ? Your phone can performed good with Spanish ROM but mine cannot, haha ?
foosoomin
Any significant features implemented in this build bro? I believe speed wise not much improvement right?
So far, i only found out that Internet browsing is much faster than previous. I still do not know on other improvement
p0is0n
What internet browser do u use? I use dolphin browser, seems to be faster than the default browser.
Beefsteak
I finally flashed to the nightly build last night and it was pretty fast and simple process.
few things i noticed,
1) auto brightness does not work (it makes the screen too dim)
2) have been using htc sense UI for quite some time already so too used to it but now changing over to ADW, abit different.
is the auto brightness thing a known issue?
fatthumb
The auto brightness is not a bug. I believe they (CM team) actually implemented a more sophisticated criteria for the auto adjustment settings.
You can try to play around with it at Settings/ CyanogenMod settings/ User interface/ Automatic backlight. The reason it makes the screen to dim is because the room is dark, under the settings you can also adjust screen dim level (I think should be in percentage, default is 20). Else you can disable the auto brightness.
For me, I used notification power widgets and put toggle brightness modes to Auto/Dim/25%/75%/100% so I can easily switch modes whenever I feel the screen is too bright (bedtime) or too dim.
Edit: Nightly build 32 is up, download at official mirror http://mirror.teamdouche.net/get/legend/cm_legend_full-32.zip
p0is0n
dun use auto brightness, it will be too dark for your eyes. unchecked auto brightness and use the slider to adjust the brightness to suit your need.
i just flash to v31 and v32 is out. lol. what is the difference between them?
Beefsteak
anyone managed to get htc_ime to work? i tried both lo and hi res version 27 but for lo res it will force close and hi res the keyboard won't appear.
fatthumb
I tried. Mine will not fc but also won't appear =:p=:p
EDIT: I assume the person who ask in XDA thread was you, so now I have tried low res 15 and it works! :D
Beefsteak
LOL. yep, thats me.
btw i am on #32 now, dunno why i notice abit of jerkiness when switching between screens. like its not very smooth like that.
fatthumb
LOL. yep, thats me.
Switch back to #26? Overall since 26 is working fine I don't think I will change unless there are major changes.
p0is0n
guys, cm33 is out, lol, the guys behind the cm nightly series are better than htc, upgrade comes out so frequently.:D
fatthumb
Because the guy behind Legend nightly only need to take care 1 device =:p HTC has many Android devices whom users screaming for updates + when they launch the OTA updates it need to be as "bug-free" as possible :D Oh well I do agree that HTC is damn slow :s12:
foosoomin
True, they are very slow
Taiwanese people do things their work pace is very much slower than Singapore
Also, i got news that HTC Legend V2.2 Froyo will only be officially available earliest December 2010
foosoomin
p0is0n said:
where you get the news from?
I cannot tell you where i gotten from. However, this news i received is at least 85% accurate...
The Froyo "MAY" or may not come with latest Sense UI
I will check with my "super reliable tomato/chilli sauce" again
