Show off your Springboard !
derekliu
Hi guys are we still able to zhng our keyboard like this last time?
I rem i use this app called iaccess early this year, but stopped using it when they start to charge money. The above is a macbook pro keyboard theme if i remembered correctly
lao3hero
I think yes, if u buy a app from Cydia called iAcces
lao3hero
ok is there any other free theme that can zhng the keyboard instead? No need to be this kind of macbook pro theme so nice
Till date no winterboard theme can zhng the keyboard yet, if i 'm not mistaken; the only way is iAcces.
derekliu
For buuf fans, i got a problem to ask. I also asked in modmyi forum, but no response yet.
i copied the com.apple.springboard into my buuf2 extra theme, but the small icons for the status bar on top still wont appear buufed
1) Only the speaker icon for mute and unmute appears, so im wondering could it be the name for those individual icon is wrong? Could it be the name for those individual icon is wrong?
2) And also how do i remove the black square shadow behind my five dock icons below? It comes default with the buuf2 theme i downloaded, i find it abit irritating.
I hope if u all understand what I am talking about :D
lao3hero
Status bar icons should go into Uiimages folder IIRC
derekliu
bro thanks for ur prompt reply, i juz edited some qns at my previous post :D
I follow ur instruction i tried copied one alarm clock status bar icon to the Uiimages folder and respring, still cant get it :(
lao3hero
stupid qn but u sure u copied to the right UIImages folder of the right theme rite? If so it should work. Else, after copying, disable your Buuf theme, respring. Then re-enable Buff theme and respring. Should work liao.
If still fails, go modmyi forums and.........................
buy Elite Pro HD theme :p
Elvis_j_s
Hey bro.
Can winter board change the slider pattern?
I tried mine, but it could not change..
Is it becos i neve purchase lockinfo?
lao3hero
Hey bro.
to specifically change slider, u need to use programs like WinSCP or iFunBox to go into the iphone's directory to change it.
derekliu
I think there is some issue btw buuf2 and iOS 4.1, thats why i cant update my status bar icons.
PES1989
How to make the words appear on the left hand side of the theme in the black box? Thanks. :)
ducky_88
Oh then u just go to download some themes and use WinSCP/iFunBox to put the theme inside, then go to Winterboard enable it and respring it :)
erm. this part i quite not understand. got any guide like step 1, step 2 & so on. sorry for the noobness. :D
