Introducing the new standard in stranded silver wire; TWag. Custom made and developed over 2 years from CryoParts.
When flexibility and performance is needed, the Elite TWag replacement cable is your perfect match!!
Made from the newly advanced TWag CFDCT-UP-OCC high stranded silver wire. Terminated with the amazing sounding Viablue 3.5mm connector. The TWag is specially cryogenically treat by CryoParts using the exclusive "CryoFreeze" process.
For more information on CryoFreeze, you can find more information on CryoParts website:
www.cryo-parts.com/whycryo.html
Wire details:
www.cryo-parts.com/cryoparts_twag.html
This also comes in black earpiece connectors!! Please email me to indicate this.
csanborn@whiplashaudio.com
The replacement cable measure comes with a Hand Made solid block of babenga wood. This helps to dampen the cable and adds to the overall look!!
