[Official] TF10 Appreciation thread
jermx9
Lune cable from Null audio. If you want i can give you his number. PM me :) Lune cable about $150
jermx9
For me i think the es2 is more of an upgrade for comfort and slightly on sound. I prefer the lune cable over the es2 and the twag over the lune :)
shawn_sboi
Okay i think i will go contact null audio. Going do remolding also for my TF10 + change cable.
stan91
stan91, wow awesome! reshell seems worth it. $200-300. I don't mind though. I don't like the design for TF10. I want custom mold for my ear de. LOL
http://www.null-audio.com/store/index.php?main_page=product_info&cPath=67&products_id=195
this one for TF10? or no?
What's differents between TF10 and TF10Pro
Ya for tf10.
I not sure abt the diff lei. But should be same ba i guess?
Anyway, i suggest u reshell through stereo ba, cause from what i heard right, it's very hard to contact null audio. So for that 3-4 weeks, you won't know whats happening. At least from stereo, you will feel safer ahahaha.
Just reshell through stereo and get lune cable from null audio lor.
I now also considering whether to reshell my tf10 or my SM3. :s22::s22::s22:
If reshell tf10, then will sell SM3. But i like SM3 yet don't want reshell cause void warranty. :(
shawn_sboi
What about TIPS? any recommendation? i was on UM1 and using comply, super comfortable, but use awhile must change. I need something that can last long+good sound overall.
shawn_sboi
Ya for tf10.
Omg? hard to contact null audio? does null audio do reshell cheaper?
cause null audio quite cheap leh.
jermx9
Ya for tf10.
I think must contact the owner directly then he'll reply. I sms him directly got reply. He's running the biz alone iirc. Now i'm thinking of either lune cable for my um3x or tf10 :)
jermx9
Try shure olives :) good for me :)
stan91
Ya it's cheaper. But go through stereo like more safe. ;x.. At least you know what's going on. ahahaha.
jermx9
For null audio reshell and add one driver way cheaper than stereo
shawn_sboi
Stan91, so u mean reshell at stereo then get cable via null audio then ask stereo do?
i want to do all at once leh...
x3dnd3x
upzzz TS for starting the thread.... looking fwd to use it when it arrives....Dec 2 will arrive BDL...then another 3-4 days will reach SG...
Hmmn. maybe when all get their units liao we can organize 1st meet-up all go and consider buying the various cables at STEREO?
Why don't when all of your units come , then consolidate all the people who want to change cable and 1 shot order at Stereo ?
By doing so , maybe they're able to give a better pricing ? :o
