westone is using 1040 iirc, saw a similar qn like this beforeThe 1020 is it the same size as the westone deluxe case?
Okie. Can the i1015 fit the TF10 or Shure SE535 besides the iPhone/iPod Touch? Would be interested to know the price.
I haven't seen any mention here, you can try the alternative method of wearing your tf10 (or any UEs for that matter). Been doing this since my first UE.
http://archive.slickdeals.net/showpost.php?p=25485664&postcount=1368
You just need to swap the cables. At least now you dun look like a dork with something sticking out of your ears.
it has a "built-in cable manager" that can hold earphones/cables.
1 set of earphones no issue.
however, we are out of luck. currently no stock.
Oh I see! Any estimated arrival date for the shipment? Also, is there any place where I can view the item and try it first?
sorry NightFalcon, I have no visibility on supplier's shipment. Will try to find out more and let you know of any updates.
Regarding item view/try-out.
This is a 1-time thingy as a colleague returning from the US fowarded the lobang/contact. So I cannot help you on that. My apologies.
anyone knows if the case provided by triplefi 10 is thicker or the pelican 1010?
and will the foam rubber in the pelican case get stains easily or turn black overtime if let say i get clear/yellow?
Wats the diff Between otterbox case and pelican?
