[Official] TF10 Appreciation thread
frelouie
Okie. Can the i1015 fit the TF10 or Shure SE535 besides the iPhone/iPod Touch? Would be interested to know the price.
it has a "built-in cable manager" that can hold earphones/cables.
1 set of earphones no issue.
however, we are out of luck. currently no stock.
poingyo
I haven't seen any mention here, you can try the alternative method of wearing your tf10 (or any UEs for that matter). Been doing this since my first UE.
http://archive.slickdeals.net/showpost.php?p=25485664&postcount=1368
You just need to swap the cables. At least now you dun look like a dork with something sticking out of your ears.
meaning..
the "LEFT" earpiece wear on your right ear
the "RIGHT" earpiece wear on your left ear.
in the end we swap the cable side.. am i right? :look:
Kyushinro
yap. just unplug the right ear piece, fix it on the left cable and vice versa. then wear it flush against your ears, looping the cable around your ear as usual.
NightFalcon8
Oh I see! Any estimated arrival date for the shipment? Also, is there any place where I can view the item and try it first?
frelouie
sorry NightFalcon, I have no visibility on supplier's shipment. Will try to find out more and let you know of any updates.
Regarding item view/try-out.
This is a 1-time thingy as a colleague returning from the US fowarded the lobang/contact. So I cannot help you on that. My apologies.
NightFalcon8
No worries, brother. Will look forward to your updates.
trickle_on
DuaPuiJi
anyone knows if the case provided by triplefi 10 is thicker or the pelican 1010?
DuaPuiJi
and will the foam rubber in the pelican case get stains easily or turn black overtime if let say i get clear/yellow?
frelouie
1010 will be bulkier and I believe slightly heavier.
TF10 = metal
1010 = molded plastic
protection >> no fight. 1010 wins. it can withstand sudden and severe impacts (crushproof). these are built to last. however, if you don't forsee a major accident with your earphone case, 1010 may be an overkill. Added advantage = can keep accessories in moisture-free environment.
noobzpro
guys how many of u gonna remould ur tf10?? and if yes by which company inearz or unique melody
frelouie
I have had no issues with my clear/blue 1050 - it's been 1 year. I'm not a particularly careful person. but I do keep my coffee away from my toys. :)
the yellow tray (some refer to it as liner) would be rubber and is washable.
jus fyi, it can be bought as an accessory. But only in black.
frelouie
Wats the diff Between otterbox case and pelican?
otterbox VS pelican
case only, no tray VS case with rubber tray (liner)
Waterproof VS watertight
rated to 100ft depth (~30m) VS not rated - cannot be submerged (for models w/out o-ring seal such as 1010)
Randius
Though I no longer looks like a Frankenstein with the reverse mod, I still cannot get a proper seal with them. It is often a hit-or-miss thingie.
jermx9
but with the flip mod i'm able to wear the tf10 faster. before the flip mod i can hardly even put it in. after flipping much easier. The seal is abit different now. Rmb to switch the tips if you do the flip mod.
