[Official] TF10 Appreciation thread
frelouie
frelouie pls help me decide which one i will need. i want one red / clear without foam. thanks a lot. i cant reply to anything else any further, now in airport using internet kiosk. :D
Ok guys.
Need some help here.
Anyone can tell me dimensions of madcap amp?
I'm not familiar with portable amps - use headphones with dedicated amp mostly.
Thanks in advance!
jermx9
Ok guys.
Thanks in advance!
About the same size as iPhone. But height slightly taller.
zhuang_zijian
pls pm madcap for info. i may go with either the premium or the normal version. so just take the bigger specs of both. thanks a lot. btw if its same height as iphone then why cannot use 1015 case? just wondering.
frelouie
reason = form factor / fit.
i1015 is designed for, and holds iphone/ipod touch very snugly.
ok, will help you check dimensions.
do you have a budget for the case?
weiiix
Update on interest check for Pelican cases - details above.
Folks that have expressed interest:
1. shawn_sboi (tentative) - clear/red
2. randomguy123 - clear/red
3. zhuang_zijian
4. noobzpro
5. ceestudent 1010 clear/blue
6. weiix 1010 clear/red
7. deathie74 1010 clear/blue
Just got home. Received a new 1020 and 1150 today and both did not come in retail packaging. Just a simple clear plastic bag holding it. Original Pelican tag intact. Both cases in brand new condition with no scratches.
The 1010s to be ordered will likely arrive in the same way.
If anyone feels uneasy with packaging, please feel free to withdraw your name.
No problem.
But do let me know by 12 noon tomorrow.
bro shawn_sboi >> can you confirm order/no order?
bros zhuang_zijian & noobzpro >> color preference?
Folks, call for MO will close 12 noon tomorrow.
If # of orders = 6 or more, I'll go ahead with it. Else, will kill MO.
COD.
Self-collection at central location, time and place to be agreed upon.
hey sorry, i would like to pull out.
Koelsch
could you recommend the best pelican case for a custom iem + twag cables? i don't wanna curl my cables up too much.
ceestudent
@freelouie
Is the pelican case genuine bro?
Just want to confirm only. Dun mind without package as long it is genuine.
AhHuat
want to sell whiplash twag cable non-om version 48"
just fyi , retail price is usd 225 (excluding shipping)
interested , let me know.
Munchies
If I use a triplefi 10 vi cable can I get it to work with my iphone? Anyone doing an MO for the westone ES2 cables?
frelouie
Last call for Pelican case MO.
folks, I'm having a crazy day at work so have not ordered the cases. :s27:
there is thus an extension of 6 hrs. :)
Will close at 6pm this evening and share final order list.
frelouie
taking into consideration bulk of case + minimal winding of cables
recommend either 1020 or 1040
to minimize winding >> most significant factor is planar area of internal tray.
you don't need depth as intention is to only hold IEM + cable.
examples:
1010 = 11.1 x 7.3 x 4.3 >> area = 11.1 x 7.3 ~ 81
1020 = 13.5 x 9.0 x 4.3 >> area = 13.5 x 9.0 ~ 121.5
>> external volume = 1060cm3
1030 = 16.2 x 6.7 x 5.2 >> area = 16.2 x 6.7 ~ 108.5
>> external volume = 1155cm3
1040 = 16.5 x 9.8 x 4.4 >> area = 16.5 x 9.8 ~ 162
>> external volume = 1313cm3
1050 = 16.0 x 9.3 x 7.0 >> area = 16.0 x 9.3 ~ 149
>> external volume = 1921cm3
Durian_Puff
3. zhuang_zijian
4. noobzpro
No problem.
COD.
Hi,can I have 2x black pelican case(1010). Just to check it is top clear and bottom black?
