Exchange Rate
albertchng
TaoYuan airport today 22.62.
Should just change there, if you kiasu or kiasi, can change some in SG and some there.
angcsbenny
tinking of going in next yr march.. do u tink the rate will increase?? coz now gt election ba.. so tink this time abit low.
the reason why sgd to twd rate drop is nothing to do with election.. its due to ireland bailout once that is fixed should get better
angcsbenny
according to my calculations based on the usd rate from mustafa and bank of taiwan exchange rate. IF u change ur sgd to usd than change usd to twd in taiwan.. u will get a rate of 22.6.. too much hassle tho.. good if u have usd tho
angcsbenny
just changed at the money changer opposite 313 somerset.. 22.37.. not bad considering taipei airport rate is 22.43 now
Keiryl
=( 22.43 at Taiwan airport? That's really quite low.
When I went in July this year, it was 23.67..!! Should have changed more then!!!
Going again in end-Dec, gotta change some in Singapore 1st.
Do keep us informed of latest rates../
darkchamber
would an exchange rate of 22.37 and a 22.42 make any difference? 'cos i dont find it a point to travel to every money changer in singapore just to check the rates..
pacetone
Even if you change SGD10,000, the difference is about SGD22, and if you change less than that, then it is merely a few dollars only.
ApeTruelove
no u are wrong if u were to change $1000 when the rate is 23 and 22 u will lose about ntd1000 which is about $40plus sing dollar
pacetone
I'm replying to darkchamber who was asking the rate of 22.37 and 22.42, difference of 0.05. Of course difference is much more for 23 and 22.
